Frigidaire FAC126P1 Thru-Wall/Window Air Conditioner
Problem for Frigidaire FAC126P1 Thru-Wall/Window Air Conditioner
A lot of water leaking out of A. C. into neighbor's window below
By pnz400 on Aug 17, 2009
An unusually high amount of water is leaking out the right front side of my window A.C. unit (not into the room, but right by the window pane). It is ruining the wood molding around my window, and leaking into the neighbor's window below me. How do I fix this??
Best Solution
posted on Aug 17, 2009
Very Helpful)
498n
Rank: Guru
Rating: 91%, 190 votes
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks! I'll try that. " - pnz400
Popular Solutions for Frigidaire FAC126P1
Questions and Unsolved Problems for Frigidaire FAC126P1
Do you recommend Frigidaire FAC126P1 Thru-Wall/Window Air Conditioner?
Answer
Answer
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the... (More)
Answer
safety check list for user to prevent fire in room air conditioner
Answer
the air unit does not blow cold air, it blows a little cold air, but not enough to keep the room... (More)
Answer
blower motor making a loud noise from the motor from a frigidaire ac unit 12,000 btu's
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAC126P1...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
