Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Linksys adapter Experiencing poor voip voice quality. Could I have problems with the adapter, modem or router? Is there an easy way to check to see if they're working properly? Thanks
  • 173 Answers
Factors that Affect Voice Quality
  • Audio Compression Algorithm
    Speech signals are sampled, quantized and compressed before they are packeted and transmitted to the other end. For IP Telephony, speech signals are usually sampled at 8000 samples per second with 12-16 bits per sample. The compression algorithm plays a large role in determining the Voice Quality of the reconstructed speech signal at the other end. The SPA supports the most popular audio compression algorithms for IP Telephony: G.711 a-law and µ-law, G.726, G.729a and G.723.1. The encoder and decoder pair in a compression algorithm is known as a codec. The compression ratio of a codec is expressed in terms of the bit rate of the compressed speech. The lower the bit rate, the smaller the bandwidth required to transmit the audio packets. Voice Quality is usually lower with lower bit rate. However, Voice Quality is usually higher as the complexity of the codec gets higher at the same bit rate.
  • Silence Suppression
    The SPA applies silence suppression so that silence packets are not sent to the other end in order to conserve more transmission bandwidth. Instead, a noise level measurement can be sent periodically during silence suppressed intervals so that the other end can generate artificial comfort noise that mimics the noise at the other end using a CNG or comfort noise generator.
  • Packet Loss
    Audio packets are transported by UDP which does not guarantee the delivery of the packets. Packets may be lost or contain errors which can lead to audio sample drop-outs and distortions and lowers the perceived Voice Quality. The SPA applies an error concealment algorithm to alleviate the effect of packet loss.
  • Network Jitter
    The IP network can induce varying delay of the received packets. The RTP receiver in the SPA keeps a reserve of samples in order to absorb the Network Jitter, instead of playing out all the samples as soon as they arrive. This reserve is known as a Jitter Buffer. The bigger the Jitter Buffer, the more jitter it can absorb and the bigger the delay it can introduce. Therefore the jitter buffer size should be kept to a relatively small size whenever possible. If jitter buffer size is too small, then many late packets may be considered as lost and thus lowers the Voice Quality. The SPA can dynamically adjust the size of the jitter buffer according to the network conditions that exist during a call.
  • Echo
    Impedance mismatch between the telephone and the IP Telephony gateway phone port can lead to near-end echo. The SPA has a near end echo canceller with at least 8 ms tail length to compensate for impedance match. The SPA also implements an echo suppressor with comfort noise generator (CNG) so that any residual echo will not be noticeable.
  • Hardware Noise
    Certain levels of noise can be coupled into the conversational audio signals due to the hardware design. The source can be ambient noise or 60Hz noise from the power adaptor. The SPA hardware design minimizes noise coupling.
  • End-to-End Delay
    End-to-end delay does not affect Voice Quality directly but is an important factor in determining whether subscribers can interact normally in a conversation taking place over an IP network. Reasonable delay figure should be about 50-100ms. End-to-end delay larger than 300ms is unacceptable to most callers. The SPA supports end-to-end delays well within acceptable thresholds.
Posted on Dec 05, 2007
What I have understand from your question is that you just want to get your VoIP device working but probably you may need a SIP account from a VoIP service provider.
Nov 03, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
Can a linksys router support voip and vpn?
It depends which model and which device because all devices differs in nature and the best way is to check each model`s manual or datasheet.
Jul 20, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
I just set up a new linksys wrt54g without a sim card. now my home phone wont work. but when i unplug the phone from the phone port my internet wont work? do i need a sim card for my home phone to work?
More information is needed about your setup.
Do you have:
cable modem <--> router <--> computer
cable-telephone-box <---> telephone
DSL-modem <--- VOIP adapter --> telephone
and VOIP adapter -> WAN port on WRT54G <--> computer
Please clarify.
Jul 18, 2010 | Linksys Wireless-G WRT54G Router
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Linksys Router Issue
My VOIP Adapter is lock I can't reach the web page
Jan 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
Hope this will help you solve your VOiP problem...
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I want to setup a wireless network with 3 deskops and atleast 2 laptot
Linksys has a slim Web server built into their routers and a nice little Web based configuration management interface. You can configure your router to pass or filter IP multicast. Most of the Linksys routers have a filter configuration page where you simply check to filter/pass multicast traffic. As for the VoIP/Teleplhony trafic, you should select one of the routers that allows Quality of Service (QoS) - only some routers support this. The QoS router may recognize the voice traffic automatically but at most you would have to specify the applicaation/ports to give priority to. Again, all is done easily via the Web based management utiility - no CLI needed.
Aug 04, 2008 | Computers & Internet
Firmware Upgrade?
i have pap2 phone adapter it has some problem. i says This is the voice massage i have got it from my phone.
Connected in the incorrect phone port. Please try other port. If you believe
your correct port. Please log on to your web account to check your states of
your service O108.
This is the voice massage i have got it when you pickup the phone
immediately the voice massage will comes.
please help me anyone
Jun 08, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
339 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
