My mouse dose not move
  1. no mouse connection
when i plug my mouse in it dose not move the cruiser i don't know what to do
Ci60 put batts. in plug usb into port on cumputer tried to use dosen't work.
    Problem Solver:
  • 10 Answers
Right click my computer go to properties then goto hardware then device maneger check the usb to make sure it is instaled corectly
Posted on Dec 03, 2007
SOURCE:
Mouse come on and dose notthing when i plug it in the usb slot
Geoff: Only Wireless mice require batteries: If your Mouse is directly attached to the computer with a cord to the USB port, go to the Device Control Manager (open Control Panel on the operating system) look for input devices> Keyboard, Mice and other controlling devices: Right click and look at the PRORTIES to see if the hardware is connected and up-to-date. Update the Drivers if you can. If a delta icon with an exclamation mark appears, this means there is connection problem between the mouse/keyboard. If the USB connection works for other devices you plug into the USB port, then the problem is the mouse and not the computer.
Dec 25, 2013 | Computers & Internet
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
USB mouse not working?
Ok don't worry. Sounds like you need to Unplug the mouse for a sec then re-plug it back in to reset it. If the mouse is wireless then try replacing the batteries. Cause a wireless mouse can still turn on if batteries are weak but won't have enough power to connect to the receiver connect to the desktop/laptop. Try doing so and let me know if this solves your issue.
Aug 24, 2012 | Computers & Internet
Cursor doesn't move, but the mouse is "on"
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 11, 2011 | ACCO Brands Kensington Ci60 Mouse
Onn wrieless mouse is not working
Try replacing the batteries in the mouse. Sometimes the light will still come out of the bottom of the mouse - but the wireless signal is no good.
Also - after you replace the batteries in the mouse, click the sync button on the USB part that plugs into your computer, and then immediatly click the sync button on the bottom of the mouse.
That should do it!
Nov 14, 2011 | Computers & Internet
My optical mouse Kensington Ci60 stopped working. Changed batteries and still not working ... How can I fix it?
Unplug the USB receiver and plug into a different USB port if available. Press the connect button on the receiver and wiggle and click the mouse for the next 10-20 seconds. This should revive the mouse.
If the above does not work, you may have to reinstall the drivers.
I hope this helps.
Nov 14, 2009 | ACCO Brands Kensington Ci60 Mouse
Mouse doesn't recoonect
With the usb plugged in, restart the computer. If you move the usb mouse from port to port while the computer is on it may not recognize it. I hope this helps and please let us know. Please rate. Thank you.
Mar 11, 2009 | HP (A2839B) Mouse
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
There is a connect button under the mouse.
and there is a button on the reciever. Please press both the buttons together for 2 minutes and after this it is supposed to work. However if it is not working replace the battries and do this sync process again.
If still not working contact kensington support they will replace for you.
click on the link below to contact through email.
http://kensington.custhelp.com/cgi-bin/kensington.cfg/php/enduser/ask.php?p_cat_lvl1=8
Regards,
Mohammed
Regards.
Mohammed.
Nov 24, 2007 | Kensington 72219 Mouse
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
