Question about Refrigerators
Freezer works fine but no cold air in refrigerator...
I have a kenmore model number 72914200..the freezer is on the bottom.. the freezer is on the coldest setting and the freezer temp is 0 degrees.. i have no cold air entering the refrigerator upper compartment... also the automatic ice maker has quit working...
any help would be appreciated
  • 2 more comments
  • ikel Dec 09, 2008
    I have a similar problem, the freezer produces cold air but the refrigerator is warm instead and the food is starting to go bad. what could be the problem, the fridge is an l,g make with green ion protector but there is not cool air entering the refrigerator.
  • dchoffeld Jan 06, 2009
    freezer not defrosting
  • Anonymous Mar 24, 2014
    Freezer works fine but refrigerator is not cold
  • Anonymous Mar 28, 2014
    Freezer compartment not keeping cold
  • 291 Answers
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
My refrigerater is not cold. but the freezer is working fine. what can be wrong
You have a defrost problem Need model number to see who made your frig as Kenmore makes nothing.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Sep 10, 2009 | Kenmore Refrigerators
Kenore bottom freezer
The drain pan is located at the bottom in front of the compressor you should be able too see it when you take the toe kick off. If you go to www3.sears.com you can look at a picture of the unit just put in your model number make sure you put the number in as 596.72914200 that period is important you will need too look in the compressor section of the parts breakdown.
Jun 13, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
1,000 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
