Question about Hamilton Beach 40729 Espresso Machine
How to get new coffee holder
We lost the coffee holder (as opposed to the pod holder).  I see no place online where one can order this simple part...
If you still need the part, send me an email,
hegbus-at-mchsi-dot-com
(Address spelled for security purposes)
Posted on Aug 20, 2008
SOURCE:
Where can I buy some Senseo coffee pods?
Senseo coffee pods are available in a variety of locations both locally and online. If you prefer something local, try Wal-Mart. Otherwise, I have compiled a short list of some online options for you to order from.
http://www.senseo.com/
http://www.ebay.com/sch/i.html?_nkw=senseo+coffee+pods
http://www.coffeepodshop.co.uk/Senseo-coffee-pods-c-253.html
Feb 07, 2013 | Wine & Spirits
I need a Pod Holder (P/N 31001) for Model MES2B/W/R. Where can I find one?
web site says target or order online. web search-Toastmaster melitta one accessories.
Oct 07, 2010 | Toastmaster Melitta One:One Javapod Pod...
Top will not unlock
It seems to be caused by pressure build up (not a vacuum) when the outlet of the pod holder gets blocked. There are three plastic bolts that slide into place to lock the lid as the lever is operated. Pressure forces the lid up and increases the friction on the bolts to the point where they won't operate. Solutions 1 and 2: First disconnect Senseo from the electric supply. Solution 1 is to press down on the lid to overcome the pressure and then operate the lever to unlock. Didn't work for me. Solution 2 is to get a table knife, not sharp, no serrations but with a rounded end, not pointed. Insert under lid just to right of pod holder handle, at an upwards angle of about 20 degrees to the horizontal. Then aim for the opposite 11 o'clock position on the closed lid. With a few tries the knife blade should slide between the top of the pod holder and the rubber sealing gasket releasing the pressure. Beware hot steam/water as pressure is released - wear gloves. Open lid, unblock pod holder hole with a pin, fill and heat resevoir and then flush through without a coffee pod in place.
May 21, 2010 | Philips Senseo HD-7810 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Lost Used Coffee Pod Basket
My husband threw ours away. So I inquired next time I ordered pods, and you can buy one online when you order. Just put it in the comments box on your order form (although it may be better to call and order it, as the first time I tried this they missed it). Anyway. It was like $3.50. Then my husband threw that one away too, so I gave up. ;)
Sep 29, 2008 | Nespresso C100B Essenza Single-Serve...
Hamilton Beach 40729 Espresso Machine Logo
111 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
