Dryers Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TRY TO START DYER AND IT JUST HUMS I HAVE A FRIGADARE ELEC FRONT LOADING DYER
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on Aug 17, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
598801
Points
5720
The belt may have broken, otherwise you have to use a multimeter to troubleshoot the problem.
I have a stackable frigadare w/dryer. Washer works great but the button to start the dryer just hums. Belt is ok.
It seems like this dryer need new dryer motor
In order to be sure ,take belt off and try to start dryer ,if dryer still humms it is motor problem for sure,
Torro elec start just hums when I push start will not turn ovger
If you pull the starter rope, does the engine turn over OK? If it does, then the starter needs to be replaced... or if it's 12V, the battery may be dead.
If you can't pull the starter rope, either, then either the engine is seized or something is obstructing the mechanism - branches? Rocks? A rat's nest?
Mar 05, 2014 • Garden
I have a frigadare affinity front loading washer and when i try to start a wash cycle the door locks and just as its ready to start running water it shuts off and if i go right behind that and just hit the...
Typically washing machines have a swtich in them that is pressure actuated, has a tube that goes up the cavity ( inside the outer tub ) and uses the water height to determine to shut off the water. If this hose is broken or something is plugged in it, it could think that it already has water or that its not filling at all (as long as its already started the water). Other wise I would make sure the washer knows the door is latched with some sort of indicator, because if the machine thinks the door is still open it will not fill.
Try to start dryer when you push button it just hums checked elec. it is okay
You either have something in the blower wheel (maybe fell down thru the lint screen area) or a bad motor . Here in the outskirts of Dallas , we've found snakes which have crawled in thru the vent hose , caught in the blower causing the same....just a hum but no start .
1helpful
Back of dryer gets hot
id say your limit switches arent working correctly
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Dyer on combo won't start
This could either be a bad start switch or door switch
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
