Question about Psion Workabout MX
Special communications how do i get out of the special communications screen?
Press the psion_key and the x_key at the same time
Posted on Jan 23, 2009
2002 chevy malibu cranks wont start. fuel and temp gauge dont work. radio reads cal
Cranks won't start , Did you check for spark ,fuel pressure ?
Radio Setup .Will the vehicle communicate with a scan tool ? Fuel an temp gauges not working are probably bad step motors inside the instrument cluster that controls the gauges . Where do the gauges read 0 or something else ?
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the engine coolant temperature. The BCM converts the engine coolant temperature into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The engine coolant temperature gage defaults to 38°C (100°F) or below if:
The PCM detects a malfunction in the engine coolant temperature sensor circuit.
The BCM detects a loss of class 2 communications with the PCM.
The IPC detects a loss of SPI communications with the BCM.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the fuel level percent. The BCM converts the fuel level percent into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The fuel gage defaults to E (empty) if:
The PCM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
DTC P0462
The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the body control module (BCM). The BCM converts this data and sends a fuel gage percent deflection to the IPC via the serial peripheral interface (SPI) in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics.
Have
For the DE 100 series radio, complete the following procedure, using a scan tool, in order to properly set up communication:
  1. At the Main Menu screen, select: Diagnostics.
  2. At the Vehicle Identification screen, select the following options:
  3. ?€¢
    Model Year
    Passenger Car
  4. At the System Selection Menu screen, select: Body.
  5. At the Vehicle Identification screen, select the Platform type.
  6. At the Body screen, select: Radio.
  7. At the Radio screen, select: Special Functions.
  8. At the Special Functions screen, select: Radio Setup.
  9. At the Radio Setup screen, press ENTER. The following test will set up a new or existing radio.
  10. Select one of the following options:
  11. ?€¢
    USA/Canada
    Export
  12. Press the ENTER key.
  13. Verify that the scan tool displays "Test in Progress."
  14. Verify that the scan tool displays "Test Completed Successfully."
  15. Press EXIT on the scan tool.
Important: The radio set up will configure the following systems:
LEARN VIN
Diagnostic Trouble Codes
Class 2 Radio Messages
Country Code
Chime Volume
Chime Level
12/24 Hour Clock
Without learning the VIN, the radio will display a locked message (LOC).
The radio setup procedure will also clear the following messages:
CAL
CAL ERR
CALIBRATE
May 29, 2016 | Cars & Trucks
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
Phone will ring but there is no communication capability suddenly, no special events
It is the problem of your phones software. Please change the software or change your phone
Sep 12, 2013 | DFE Communications Corporation Touch N...
Lost communication with ecm/pcm lumina 2007
You will need to have the dealer fix this, it requires special equipment to diagnose and repair.
Sep 14, 2012 | Chevrolet Cars & Trucks
None of my guages are moving also i canot see any information
{: ) If nothing at all works on your cluster and the information screen is totally blank, try checking the IPC DIC fuse10amp and IGN E fuse 10amp at the underhood fuseblock. If both are good, then the cluster should be removed to check for poor terminal connection, or it could be a wiring issue. Make sure power from the fuses is reaching the cluster terminals, and check the black wire terminal for a good ground.
It is also possible that the cluster is not communicating. A scan tool can determine quickly if the cluster is communicating, and it even have these special functions to test your gauges and indicators.
If all tests failed, then you will need to replace the instrument panel cluster and have it programmed.
Mar 11, 2011 | 2005 GMC Yukon
On a cosmic communications wpdvd 296 the screen keeps asking for a password?
If you push the eject button so the little lcd screen says open then type in 5168 with your remote. This will take you to a special menu if you go down to ratings then hit enter you can choose the rating you want. Then hit setup to finish.
Apr 05, 2010 | Televison & Video
Cosmo Communications DVD Model WPDVD-296 Password.
If you push the eject button so the little lcd screen says open then type in 5168 with your remote. This will take you to a special menu if you go down to ratings then hit enter you can choose the rating you want. You can also set up the password. Default password is 0000. Then hit setup to finish.
Oct 22, 2009 | Televison & Video
Changing the Spark Plugs. Do you need a special
There is a special Spark Plug socket for removing plugs. The engine does not have to be moved.
Oct 09, 2009 | Socket Communications OTC Tools &...
Psion Workabout MX Logo
222 people viewed this question
Top Psion Computers & Internet Experts
Marvin
Marvin
richie46
ray gallant
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
