Question about Sony KV-32S20 32" TV
Picture flashes slowly off and on
When tv is turned on picture flashes slowly off and on,then more rapidly,then stops for a while.
I had the same problem, if you have a bit of electrical experience and soldering, you connect diodes from R,G,B out to IK in on main board...let me know if you are interested.
Posted on Dec 10, 2007
Tv picture flashes.
This problems could either one the t-con board is bad or the tv LCD screen panel itself it is slowly dying,than the tv not worth repairing because the tv internal LCD screen panel itself tubes lamps it is shorting out internally.
Oct 24, 2011 | Dynex DX-LCD32-09 LCD TV
2005 honda odyssey homelink programming
If you just received your vehicle and have not trained any of the buttons in HomeLink before, you should erase any previously learned codes before training the first button. To do this, press and hold the two
outside buttons on the HomeLink Transceiver for about 20 seconds, or
until the red indicator flashes.
Release the buttons, then go to step 1.
If you are training the second or third buttons, go directly to step 1.
1. Unplug the garage door opener motor from the electrical outlet.
2. Hold the end of the garage door opener remote 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red indicator in HomeLink.
3. Press and hold the remote transmitter button and one of the HomeLink buttons at the same time.
If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indictor in HomeLink continues to flash slowly (does not flash rapidly), your remote transmitter may stop transmitting after a short time. Go to step 4.
4. Press and hold the remote transmitter button and one of the HomeLink buttons at the same
time. While continuing to hold the HomeLink button, press and release the remote transmitter button every 2 seconds. If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indicator in HomeLink continues to flash slowly (does not begin to flash rapidly), repeat steps 2 thru 4.
5. Plug in the garage door opener motor, then test the HomeLink button by pushing it for about 1
second. If the button works, programming is complete. If the button does not work go to step 6.
6. Push and hold the HomeLink button for a few seconds, then watch the red indicator on HomeLink.
If the indicator stays on or flashes slowly, repeat steps 2 thru 5. If the indicator flashes rapidly
for 2 seconds then stays on, you have a rolling code transmitter. Go “Training with a Rolling Code System”
7. two HomeLink buttons to operate any other compatible remotely controlled devices around your
home (lighting, automatic gate, security system, etc.).
Repeat these steps to train the other
Jan 05, 2010 | 2006 Honda Odyssey
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Display lights flash
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Picture starts flashing slowly and then more rapidly
if your handy and know your way around , open the TV to get inside and do a visual check for any DRY SOLDER on the PC board .specially around the POWER SUPPLY AREA and the
horizontal output area , those area gets a little heat on the board . do some REsoldering. if you can take out the PC Board
and do the inspection , will be much better . hope this been helpful. good luck
Apr 23, 2008 | Toshiba 23HLV84 23 in. TV/DVD Combo
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
Picture Flashes off and on
probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Jan 31, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
