Question about Nikon D50 Digital Camera
D80 lcd flashing "F- -"
HI...I have an out of teh box D80...all standard....tried removing lense, reseting, etc.,..no luck...thgoughts?
  • rayray34 Dec 19, 2007
    the nikon D80 will not shoot a picture, it will only flash F--. How do I fix this?
    also, the only time it takes a picture is when it is on manuel mode, and in this situation i can never focus the lens
Ive had this problem before, on my camera it means that the lens isnt rotated all the way onto its engaging point on the lens mount... it gets a little loose and shifts out of the way sometimes...
Posted on Jan 31, 2008
  • 101 Answers
The lens is not seated properly !! you can hear a clicking sound when it sits perfect !!
did u try mannual focus ??
or did u try the auto mode ??
Posted on Mar 10, 2008
    Novelist:
  • 148 Answers
Could be out of range for focus capabilities of the lens/body.
otherwise, try removing the battery and then reinserting it after 10 seconds. that should cause a full reset.
if the camera is set for a range the lens can handle, then you may need to have it serviced.
some camera boards cause the camera to blink and not shoot if there is not enough contrast to the subject for normal focusing.
one thing to try, use it in auto focus mode to determine the correct settings and then switch to manual to see if those settings work.
mark
Posted on Dec 22, 2007
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
Error message on my Nikon D80
I have the same message r07 on the same camera & lens combination. It is an lens error message that the lense will not focus. You can manually focus the lens in the auto mode and the camera will allow you to take a picture. I have been told it is the MR unit and cost of repair around $135.
May 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 suddenly stopped taking photos while I was in Auto mode. I noticed the flash stopped releasing. I've changed lenses, reset the camera's green buttons, switched out the card, reset the clock. It...
Hi, Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
May 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80. The flash is not working.
if u r getting green signal of flash charging,then discharging section is defective,sochaque the section replace the parts xenon tube etc or take it to a tech.
Apr 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
D80 SLR lens /flash prob lem
What are your other lenses? If they're not AF lenses, you're not going to get autofocus or metering.
Is your flash not working when popped up? Remember that the flash won't pop up automatically in Manual mode.
Oct 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Compare the Nikon d80 to the new d90. Can I use all my manual focus lenses from my Nikon film cameras? Also, all my filters and flashes.
All old lenses will work on the D90 the same way they work on the D80. Filters depend on the lens -- they either fit or they don't -- the camera has nothing to do with that. I wouldn't use old flashes on new DSLRs.
There really is no difference between the D80 and the D90 as far as lenses and flashes are concerned.
Sep 22, 2008 | Nikon Cameras
AF not working on Nikon D80
release the lens at smallest aperture then reattach....
Jun 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
D80 and SB-600 FV Lock doesn't work anymore
In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
Also, reset you flash by turning on the power and removing the batteries and re-install them.
Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon D50 Digital Camera Logo
1,278 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
