Sir,
If the freezer fan is running (when the compressor is running), read on,
otherwise replace the freezer fan. The defrost system has failed. There
are three components, and I recommend replacing all three. These
include a defrost timer (usually located somewhere in the food
compartment, on the rear of the fridge, or behind the kickplate), and a
defrost heater and defrost bi-metal (both located in the freezer
section where the coils are. I recommend you unplug the unit overnight
to allow the ice to melt before doing this repair.
You have a defrost problem which is common to all frost free
refrigerators. To get you through until a diagnosis can be made,
remove all the food from your freezer section and then the rear
evaporator panel. With a hair dryer, remove all the frost you see
behind the panel. Put it back together and your unit will work again
for about 5 days until it start building up with frost again.
Thanks
Good luck
