Check your Speaker control button. Most receivers have a small button on the front used to control your choice of Speaker Set A, B, A & B, or NONE. It's possible you have inadvertently pressed the button and set it to where no speaker set is selected. Therefore, no sound.
Another probable cause is that one of your speaker cables may have become dislodged at the back, and if your system has an overload control mechanism, it's preventing sound to come out to avoid damaging your output transistors, your speaker system, or both.
The last (I hope not) possibility is that the volume may have been cranked up too high, that either the output resistors may have blown on your receiver, or your speakers may have given out the ghost due to too high a signal.
The receiver use to turn on but then turn off randomly, ant the little ECO led light would come on....
(More)
The receiver use to turn on but then turn off randomly, ant the little ECO led light would come on. But the receiver wound not turn back on. The only way you could get it back on is yo unplug and plug it back in. So i opened it and messed with the main wires going to the front panel i unpluged them and pluged them back in a couple of times and it would turn on but then turn back off. Now i think i did something Because the ECO light wont turn on it makes no sound when i plug it in nothing happens. if anyone could help that would be really great thtank you
