Question about Harman Kardon HK19.5 Computer Speakers
Transformer output Can I use a transformer with a 15v 2 amp output in place of the standard transformer which has a 15v 1 amp output?
    Problem Solver:
  • 10 Answers
The volts are not as important as the amps the amps must be the same
Posted on Dec 02, 2007
SOURCE:
Im trying to repair a Bx4500h. there is not output, the preamp sections works and the transformer works. I tested both. Im thinking its a problem with the 3080 IC underneath the amp board. Theres 2 cables...
Well, first off, if this is an IC output, depending on the rated watts per channel, you will certainly need a rail volt greater than + - 15V. That would be for a regulated voltage somewhere else in the amp.
Mar 07, 2015 | Audio Players & Recorders
How do you wire it in? Orion 300 prq equalizer
the prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Aug 09, 2013 | Orion 2500D Car Audio Amplifier
I have a Roland AC60 amplifier that I brought from Australia to the US. The Australian version of this amp runs on 240 volts not 110. My question is; 1) does anyone know if converting this amp to...
The only simple way that I could think of is for you to purchase a STEP DOWN TRANSFORMER rated at 500 watt, 110 volts, 60cycle. The transformer inside that amplifier have four output 12v and 15v DC.2amps It will be hard to get the transformer for that! Hope that might help you! taah!
Nov 18, 2010 | Roland Ac60 Acoustic Chorus Guitar...
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
Transformer main coil shorted.
You have to do the math according to the circuit path, and all components in between. Break out the voltage meter.
Sep 26, 2007 | Aiwa PX-E860 Turntable
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
Harman Kardon HK19.5 Computer Speakers Logo
248 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
