Question about Sony KP-51HW40 51" Rear Projection Television
Blurry picture Our Sony 51' television has a blurry picture. Is there a way to focus the projectors or would perhaps cleaning the lens help. I have not opened the rear of the set to see how it works.
    Genius:
  • 1,694 Answers
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Posted on Dec 04, 2007
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
My pictures are coming out blurry, after a year of good quality.
Check that the lens and other elements on the front of the camera are free from dust and grime.  The focus mechanism is not functioning properly and may need to be serviced.
Dec 12, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
40 DX - blurry pics
The lens is out of focus or the shutter speed is too slow, to determine if this is a defect or failure, mount the camera on a tripod and use the self timer or remote cable (if you have the remote cable) to take exposures while autofocusing on a neutral colored object such as a beige item,
if they're still blurry then manually focus the camera and try again.
If they are still blurry and your Nikon has a diopter focus adjuster (this is typically in the rear next to the viewfinder where you focus your eye), set the diopter to neutral and manually focus again.
If they are still blurry, remove the lens and using a cloth dampened with high percentage or denatured alcohol, clean off contact rings since this is where the lens and the camera body communicate and transfer focus data.
If they are still blurry, then use the same cleaning method for the contact ring of the camera body.
If they are still blurry use a different lens and repeat the first two steps.
If they are still blurry then you may have a smudged and dirty sensor, this is the part which actually registers the image and should be cleaned by a professional.
If you are so brave to, you can use the cameras feature to lock the mirror and expose the sensor, this is typically only done to perform a dust cleaning using light blasts of clean air and using solvents on the sensor is dangerous.
If you choose to do so anyway, use a bright flashlight and look for anything that appears to be smudging, if it isn't apparent then your camera or lenses are likely in bad need of maintenance.
Aug 23, 2008 | Nikon D40x Digital Camera
Sony KP51HW40
your convergence is trying to go out
Aug 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Jul 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Sony KP-51HW40 51" Rear Projection Television Logo
249 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
