Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
HOW TO ELIMINATE A SOUND
I am not sure but it looks like the clutch is doing an sound when the machine is working. It occurs along all the way the washing cycle. The sound is like the one you ear when a motor car belt is worn and slides. Thank you
    Champion:
  • 249 Answers
'you might have hit the nail on the head'itmay be the belt,the clutch only engages on spin.good luck.
Posted on Dec 01, 2007
SOURCE:
My dc33 is making that awful clicking sound when i use the brush. the clutch was just replaced along with the belts. any suggestions on what to look into next?
The clicking usually means a restriction in the brushroll. Make sure the brush will spin freely. If all else is good You may have a defective clutch.
Jun 21, 2018 | Dyson Vacuums
I get a whirring sound from the tranny when engaged put the clutch in and it goes away shifts easy and runs great but make sure a whir sound. 2007 Saturn Sky base model
The clutch release bearing is going bad due to incorrect clutch adjustment. Damage to clutch pressure plate will occur if not corrected
Jun 08, 2017 | Saturn Cars & Trucks
My hotpoint washing machine mod WWSR1070D5WW is making a loud squealing noise but I cant tell if the sound is coming from the clutch or the transmission any ideas?
look at the drive belt, it might be worn out
To test, just put some tar all along the inner face of the belt and run it
If noise goes off, , most surely the belt need replacement
Feb 05, 2017 | Cars & Trucks
New Holland 70a will not move in gear
if your talking about a TN70A that's a 4wd drive machine , and its got a wet clutch on it , that means it works via hydraulic pressure , make sure your oil is clean and not cloudy so it works clutch well , second that transmissions got sight plugs along the top sides , that can be removed with socket wrench to view shaft moving inside with flashlight looking for broken shaft , if all axles are not moving , then id look at clutch , if only one axle or wheel is not moving then id look 4 broken axle key , they do break sometimes on 4wd machines that the axles get in a bind on , other than replacing the oil in it , all these are shop repairs your not going to be doing them in the field
May 25, 2016 | Garden
Have a 110.22642100 Kenmore washing macihne that has a metal clang on the spin cycle that occurs every second or less. The tub does not rotate much. I replaced the motor coupling since it was split but is...
Hello Jye,
It does sound like either the clutch is bad or the Motor coupler is bad. I have included a video showing how to replace the coupler Kenmore Washing Machine Model 110 22642100 11022642100 110 22642100 Parts
The coupler is about $18 and the Clutch is about $48
Good Luck!
Rich Lilja
May 19, 2017 | Kenmore 22642 Top Load Washer
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Transmission noise - 93 Honda del Sol w/ 5-spd manual trans.
Imput shaft bearing. It just happened to me. You're looking at a $400 fix.
Mar 22, 2009 | 1994 Honda Civic Del Sol
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
2003 Hyundai Elantra won't start !!!
Could be a problem with the clutch pedal switch. I'd have a look under the dash first to make sure no wires have been knocked of the pedal switch. If there's no sound, not even a clunking sound it may be the solenoid. I'd first want to eliminate the pedal wiring. Remove the small wire on the starter (most likely a spade type terminal) and using a piece of insulaated wire attach it to the starter where you removed the spade. Flick the other end of the wire on the positive of the battery. If the starter operates your looking at the pedal switch/ relay fault. If not its the starter. MAKE SURE CAR IS IN NEUTRAL BEFORE TRYING THIS. Ignition switched off. That way it will crank but not start.
Cheers John
Dec 17, 2008 | Hyundai Motor 2003 Elantra
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
