Question about RCA F32649 32" TV
TV will not come on and if it does it just cycles through the channels...
The TV will not come on. With the remote control I can hear it click on but immediately it clicks off. The buttons on the front panel don't work at all. I took out the circuit board that has the micro switches on it and checked them out with an ohmmeter and all of them work. Sometimes I can get the TV to turn on but then the channels just keep cycling through one after the other. It will not stay on any one channel.
I put the TV in my garage (unplugged) for about a week then tried it again and it worked perfectly for about two weeks then the same problem again. I don't know what to do to fix this thing and I can not find any repair places in my metro area.
  • jcinar Dec 01, 2007
    how can I bypass the tuner? It won't allow me to change to the other inputs. If I try to switch to the other inputs it immediately switches back to channels and cycles. That also does not solve the problem of it not staying on. It does not appear to be a tuner issue but rather a programming problem.
    Genius:
  • 1,694 Answers
If tuner channels keep cycling,why not by-pass the problem?
Use audio / video inputs as source from box or VCR tuner....
Saves money every time !.............................T.
Posted on Dec 01, 2007
  • Vista Electronics Dec 01, 2007
    Sorry my suggestion did not help .....I agree that you
    do not primarily have a tuner issue. Possibly a power supply
    problem affecting common circuits.....leaky regulator or diode or
    bad electrolytic capacitor........Using schematic, check all power
    supply source voltages = if all are good, suspect bad solder
    connect since set works sometimes.................Last suspect is
    bad microprocessor IC or a part in it's circuit..................T.
The tv does not turn on when switching on?
power supply board faulty......
cheers
Dec 04, 2016 | Televison & Video
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
The front panel power button won't work and i don't have the original remote for my mitsubishi hd 1080
Check and replace the microswitch soldered diretly to front panel circuit board. You have to open the TV. Get more details from the below referred site, and by click open the ads by the side and bottom of each posts.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 26, 2012 | Mitsubishi WS-55807 TV
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Volume control does not work using the TV's remote, the cable remote or the actual volume control button on the front of the set - the volume that comes out of the TV's speakers is constant - about 33% of...
SO YOU JUST GOT A NEW TV ...BUT...THE VOLUME CONTROL IS NOT WORKING FROM YOUR CABLE BOX.
EASY! BRING UP THE IMAGE OF YOUR REMOTE FOR
YOUR CABLE (MORE THAN LIKELY, IT'S A UNIVERSAL).
CLICK ON THE REMOTE FOR INSTRUCTIONS FOR VOLUME LOCK.
IF IT'S A UNIVERSAL REMOTE, CLICK SETUP (TWO BLINKING LIGHTS) TYPE 993, AND HIT CABLE BUTTON.
VOILA! YOU CAN NOW CONTROL VOLUME FROM YOUR CABLE REMOTE!
Jul 03, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
RCA F32649 32" TV Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
