Question about Canon Optura Pi Mini DV Digital Camcorder
Playback on a different camera; compatibility
I have been using my Canon Optura Pi Camera for years with Fuji MiniDV tapes. However, all of the sudden, when the price dropped on the tapes and Fuji changed the packaging, the tapes started to jam in the camera. I cannot get the old onese and every new one I put in eventually jamps and crinkles part of the tape. There are many important memories in my tape library and I want to preserve them. How can I safely convert these to more permanent storage. I have a good computer. However, I have heard that once you convert to DVD, the compression loses fidelity and you cannot edit the videos anymore. What kind of camera can I buy that will playback my tapes in high fidelity and let me copy them to more tapes or a digital record that I can replay and edit freely in the future?
Tape won't eject on Canon Optura 20 MiniDV. About
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 30, 2011 | Canon Optura 20 Mini DV Digital Camcorder
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Canon Optura Pi Mini DV Digital Camcorder. The metal compartment holding the tape won't open. Battery is charged, everything else works. Cannot remove the tape.
Tape mechanism malfunctions can be due to many factors. A bad gear is the most likely cause and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 01, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
    Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
    MiniDV Video Head Cleaning Tape is available in stores.
    Thanks.
    Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
    Sony MiniDV DSR-PD170 won't playback recorded video
    the tape path of the camera needs to be adjusted ,so you need to get that fixed.
    regards
    Aug 04, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
    Canon Optura 40 playback - only get blue screen - no image, no sound
    Try a cleaning tape. Buy a good quality cleaning tape (Panasonic makes one) and remember: cleaning tapes are abrasive so don't overuse it! Overuse can result in the need to replace the rotating drum assy in the camcorder. I'll bet a cleaning tape takes care of your problem.
    Oct 25, 2008 | Canon Optura 40 Mini DV Digital Camcorder
    Canon Optura Pi Mini DV Camcorder
    you can use software to capture it on your computer and burn a DVD, or there are services that will do it for you for a reasonable price. Windows Movie maker will do it if you can load it on your computer. If you are not familiar with the technology then just use one of the services. Most large cities have them or you can us an online service.
    Jan 22, 2018 | Canon Optura Pi Mini DV Digital Camcorder
    Optura Pi is eating tapes
    hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
    Apr 27, 2006 | Canon Optura Pi Mini DV Digital Camcorder
    Canon Optura Pi Mini DV Digital Camcorder Logo
    56 people viewed this question
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Marvin
    Marvin
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
