Question about Mitsubishi VS-7085 70" Rear Projection Television
I have a Mitsubishi MDT4025 it goes on but i'm not getting a picture
What can I do to get this fix without taking it to the repaire shop?
Posted on Oct 04, 2008
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi vs-5041 picture intermittently goes off
my guess is convergance ic but to troubleshoot it the best soultion might be to get a can of freeze and spay it on the IC while the problem is happening and or tap the board/ic's to see if you have a loose connection,
Nov 29, 2007 | Mitsubishi VS-5043 50" Rear Projection...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
