Question about LG Studioworks 700S 17" CRT Monitor
Monitor flickers!! my monitor flickers n suddenly the display goes off...but when i slap on the monitor casing it starts working.. cud u tel me wats the problem??
  • 1 more comment
  • milapthaker Oct 14, 2008
    I have the same problem. My screen is flickering and also moving like water in side ways and sometimes straight.
    Please help me fix this problem as it is affecting my eyes and resolution.
    Milap Thaker
  • Anonymous Dec 01, 2008
    my monitor flickers and i cannot get appropriate fullscreen display in
    1024 by 768 resolution . please help
  • vinod_cool Jan 03, 2009
    even i have the same problem of flickering of monitor
I have also same problem with LG Monitor 700E, LB(in). I want circuit diagram/systematics of this monitor in PDF or any other format. Thanks in advance.
Posted on Dec 12, 2007
The problem is with dry soldering or oxidation of crt neck socket.. replace it...
Posted on Oct 02, 2008
What can i do if my monitor flickers
Posted on Sep 29, 2008
You probably didn't hit it hard enough. A sledgehammer works great just try not to touch the glass with it when you do but if you hit it just right, what's wierd is your fortune will appear on the monitor also, try this it's really wierd but THIS REALLY WORKS!!!!!!!
Posted on Dec 03, 2007
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
My microphone suddenly stop working on my compaq mv520 monitor. can you tel me what can i do to fix it?
Try deinstalling the mic and redownload and install fresh driver see how that goes should clear up any glich
Dec 30, 2009 | Compaq S510 15" Color Monitor
Monitor went dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Viewsonic monitor 17GA
What is "EHP"?
If it comes on back after a week, what do you think?
When it goes "black", is it in standby or is it still on?
Slap rear of case when it happens. Flickers screen?
Re-solder video board; particularly, the Video I.C.
Oct 26, 2017 | ViewSonic Computers & Internet
Serious problem
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Oct 15, 2007 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
401 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
