Question about Durabrand DWT1304 13" TV
Speaker for some reason the speaker isn't working. why ?
Maybe the speaker has a loss contact with the circuit. this is what we called intermitent problem. or the speaker itself is heating and losses its contact with the ciruit.
Posted on Dec 28, 2007
Sound system
If you haven't spilled anything on the Tosh or dropped it then there really shouldn't be any reason for the speaker to stop working. The speaker connector is very easy to get to. If you are confident to do a little dismantling that is. See the strip that runs along above the keyboard? This can be levered out carefully preferably using a plastic tool or screwdriver. Underneath here are four small screws which secure the keyboard in place. Once these are removed, tilt the keyboard up and towards the screen and then you have the option of releasing the keyboard ribbon connector if you need to. The speaker connector is black and red wired and is located roughly below where the 6 is on the upper keyboard. Maybe it has dislodged and just needs pressing back in. If this isn't the problem, then further diss assembly will be required to gain access to the speaker for further inspection
Sep 13, 2012 | Toshiba satellite c660
I recently replaced my door speakers and now my power windows and blower motor are not working
Check to see if the fuses to both your Windows and Blower-Motor isn't blown. The fuse-box is under the little door on the end of the dash on your Dodge RAM.
The reason I'm suggesting the fuses, is because you say that your "windows" doesn't work, and since it's all of them you're talking about, this might be the issue.
If the fuses isn't blown, then check to see if you might have disconnected the cables to your windows and the blower-motor :-)
Hope this helps!
Kind regards
//Chris-Mario
Apr 01, 2012 | 2000 Dodge Ram 1500 Truck
How do I fix faulty Jamo D165 Speakers
I just bought a set of jamo d165 speakers and one tweater isn`t working can these be replaced?
Dec 11, 2011 | Audio Players & Recorders
Only my front speakers work in my 98 chrysler
If this is the original radio, you lasted longer than most. It could be the radio or the rear speakers. Again, if the speakers are original, they lasted a while (13 years isn't bad). If you plan on keeping the car, replacing the radio with a CD unit would be advisable. However, if this is an aftermarket radio that isn't too old, I would check the speakers. They may have blown. There are many cheap replacements that function much better that stock speakers do. They are available online or locally.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
I tried to install an aftermarket 6 1/2" speaker
possible reasons:
Impedance mismatch
wiring is grounding out on frame/metal
speaker isn't OEM and is slightly "pinched" thus causing cone distortion
One of these three will be your issue.
Also, you may remove the speaker and leave it hanging with the wires attached. Knowing that no wiring is shorted and nothing is disturbing the cone, try running your stereo. Same crackling problem? It may be an impedance issue or you reversed the polarity on your speaker.
It will require some work but the solution is there if it was working before.
Apr 12, 2011 | 2003 Chevrolet Impala
My speakers make no noise in certain games , but the only subwoofer works, speakers work everywhere else though
At the 5.1 and 7.1 sound cards,you have more that 1 socket for speakers.If the jack isn`t plugged into the green one,the speakers will not work in all PC application
Oct 19, 2010 | Logitech X-530 Computer Speakers
Only used a few times and the power is on but nothing showing on the screen and theres no sound its a black ds lite
The reason the screen isn't showing-up is probably because of runny colors or blotchy colors permanently stained on the screen, even when the Nintendo DS Lite is OFF, my guess is that the liquid crystal display (LCD) is cracked. And also, there are multiple reasons for your speakers not working properly. The main reasons for the speakers not working would be the following;
  • Something small must have gotten wedged inside of the speakers.
  • A type of liquid and/or sticky substance leaked into speakers.
  • Lots of pressurized force on upper screen(which could have also caused the damage done to the screen).
What I would recommend is make an appointment with "Nintendo customer service".
Feb 16, 2010 | Nintendo DS Lite Black Console
What does the microphone icon mean on my i776 motorola
Regarding the blue microphone on your phone....I had the exact same problem. I found that I had some voice audio recordings and when I deleted them it went away. These were audio recordings I did, but for some reason the phone wanted me know I had them saved. Once deleted the icon went away. Some people have suggested it was a speaker icon, but obviously it isn't the speaker icon - looks like a speaker and the microphone...well looks like a microphone. LOL
Jan 01, 2010 | Motorola Mobility i776 Cell Phone
Durabrand DWT1304 13" TV Logo
24 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
