Question about Vicks V3100 1.2 Gallon Humidifier
Need to clean the filter
I lost my manual for the Vicks V3100. I bought a new filter today and installed it. I need to know how to clean the filter when it needs it.
Thanks
  • 2 more comments
  • Anonymous Jan 18, 2008
    I also lost my manual. I need to know what the regular maintenance is.
  • mary hunter Mar 22, 2008
    I am trying to clean and disinfect my vicks 3100 humidifier. How do I do that. I tried putting viniger in the base but it leaked out. I put the removable in the diswasher. What do I do next?
  • Larryjgoodni Oct 06, 2008
    What will stop any output ????
  • Anonymous Jan 17, 2009
    Please help ,e with the same . I lost my manual :(
  • 123 Answers
Http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Posted on Apr 18, 2008
SOURCE:
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
How do i take apart and clean my Vicks V3100 cold air humidifier?
couple of screws on the bottom, but why take it all apart when you can probably run vinegar through it and let that do the work, smells a little, so maybe on the porch...
Feb 27, 2010 | Vicks V3100 1.2 Gallon Humidifier
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V-3100E Filters
Here is a site that stocks the filters you require, but needless to say it is main order.
http://www.healthcare4all.co.uk/vicks-filter-aca3e-v3100-p-330.html?osCsid=168dab22ab1bfeb75a4095d3d6e51127
Vicks Kaz Filter ACA-3E for V-3100
Availability: In Stock (for immediate despatch)
[ACA3E]
£9.79
(incl. VAT at 15%)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
Sep 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Missing part
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is a link to the manual for the humidifier you bought.
It shows how everything comes apart and how it all goes together with the filter.
Hope this helps.
Good Luck.
Apr 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier Logo
862 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
George Merkley
George Merkley
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
