Question about Sony Walkman NWZ-B135 MP3 Player
When i click on equalizer it says cannot execute. Any suggestions
Same as summary
  • 3 Answers
I think you are having the same problem I had.
I found that if the Bass was turned on then you couldn't access the equalizer.
Once I had turned it off, no probs. To turn it off simply press the bass button on the top of the player.
Hope this helps.
Posted on Aug 20, 2009
  • GR Majdieh
    GR Majdieh Aug 11, 2014
    Ok in my NZW-B173F it works only when BASS is off. Thanks
Thanks alot neil! You solved my problem too! :D turn off bass to use the equalizer!
Posted on Jun 16, 2010
    New Friend:
Thanks brother for Ur article :D
Posted on Jan 19, 2012
  • break_awp89
    break_awp89 Jan 19, 2012
    thanks brother for Ur article :Dhelpful
  • mone_actitud
    mone_actitud Feb 05, 2012
    Remember that, according to the manual, the lifetime of the battery will be reduced to 50% while using any EQ different from the pre-set..
SOURCE:
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
Sony Walkman NWZ-B152F MP3 Player Equalizer can not execute
I have read this on its operation manual, hope this will help
*If you turn on the Bass function while the equalizer setting is activated, the equalizer setting is disabled. The equalizer setting will be resumed when the Bass function is turned off.
*While the Bass function is activated, you cannot change the equalizer setting.
Nov 08, 2010 | Sony Walkman NWZ-B142 MP3 Player
My i touch will sync apps but will not sync music from my itunes library this did work when I first got the i touch but suddenly stopped. Any suggestions as to how to get it working again ?
open the itunes>>click on your ipod>>on the summary page click on the music tab>>check sync all music>> thats it.
should work or else let me know what happened
Mar 04, 2010 | Apple iPod touch
I just bought a sony mp3 walkman nwz-b142f and when i go to the Equalizer it says ''cannot execute'' can you guys help me??
hello i am also using this player only
in order to execute equilizer pls off bass and then try to use equalizer
i am sure now u can find the option
i have read the softcopy of manuall which is available in player.....
its working enjoy!!!!!!!!!!!!!!!!!!!!! hearing songssssssssssssssss.......
Aug 05, 2009 | Sony Audio Players & Recorders
Data execution prevention
  • DEP help's prevent damage from visuse's and other security threat's that attack memory location's on your pc, by default (DEP is turned on for essential window's program's and service's only, it may be possible DEP has been turned on for all program's and service's except those you select, you can check this setting by,
  • going to the control panel,
  • click on system,
  • under the system propertie's box click the advanced tab,
  • in the advanced tab click setting's under performance,
  • from there you will get a performance option's box,
  • at the top to the right there will be a tab that say's Data Execution Prevention, click the tab.
  • from there it should be set to essential window's program's and service's only, this is the default setting.
Apr 16, 2009 | Computers & Internet
Acess denied
You certainly have an autorun installed by a virus.
A solution is to go command line and delete autorun.inf in c:\ and d:\
Another solution is to right click and choose open in the menu instead of execute. If execute is default then your computer is infected. I suggest http://downloads.andymanchesta.com/RemovalTools/SDFix_ReadMe.htm
Feb 14, 2009 | Dell Computers & Internet
Error=0xC0000022
RESOLUTION :
  1. Go to SYSTEM32 folder
  2. Locate the MSVBVM60.DLL file and right click on it, and select Properties
  3. Go to the Security Tab
  4. Click on Add. Type Everyone and hit OK
  5. Back at the Permission form, make sure Everyone is assigned Read & Execute permissions
  6. Click OK
Regards
ELLIN
Sep 19, 2008 | Computers & Internet
Sony Walkman NWZ-B135  MP3 Player Logo
3,963 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
