Question about Philips 42PFL5332D 42 in. LCD Television
42PFL5532D/05 have just got a Philips Plasma 42PFL5532D/05. On Sky and my DVD I only get mono. Yet normal TV it goes stereo no problem. Both are connected to the TV by scart cables.
  • Dynamix Jan 27, 2008
    I have a Philips 37PFL7662D/05. I too have a problem with sound. Built in Freeview & analogue is in stereo, but all inputs, scart, phono, aux etc are in MONO. I have tried scart outputs, audio outputs from both SKY & DVD, whose sound are perfect through a seperate surround sound amplifier, the tv is new and I have sent an email to Philips.
  • 476 Answers
Audio from an external input only shows as mono on the TV information display.
If you are only getting sound through one speaker of the TV, check the scart connections are all in fully, and straight.
If you are getting sound through both speakers, then the sound is stereo. Stereo only shows when there is a NICAM stereo sound source, which is only through analogue terrestrial TV.
Posted on Feb 18, 2008
Philips model #24PT6341/37 Is this TV capable of switching from mono to stereo??
Its a stereo TV. And there is nothing to do to make it mono/stereo.If yo get stereo transmission then it will automatically change to stereo and vice versa.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 11, 2016 | Philips Televison & Video
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
I just bought a Philips Smart WiFi Bluray Player BDP2105F7 and I cannot connect it to my old tv which is a sony triniton, I have image but no sound. There are two outputs on the dvd player but I have...
Your white red yellow cord is a Stereo sound + video cord. The red and the white ends are for sound the yellow end is for video - if your TV is not stereo it may not have the red and white it may only have one in which case you need to find an adapter from stereo to Mono to fit your red/white cable ends into a single connection on the TV. Or you can buy a home theater sound system and it will give the TV its signal and it will keep the stereo signal and broadcast it through the sound system.
Sep 15, 2017 | Philips Televison & Video
I can't connect my portable Philips PET721D/05 to a TV.It has AV jack and when connected all I get on TV is sound from the DVD player.What am I doing wrong?I'm using a cable that fits into AV and has 1...
The yellow connector is for video and the white conector is for mono sound. ( as standard colour codes state) so if you have the correct connections on the tv it should work. alternativly you can buy a "block" that will plug into a scart socket and you can connect the av lead to.
Mar 20, 2010 | Televison & Video
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
Nov 20, 2009 | Philips Televison & Video
Poor sound when playing dvd
Have you checked your TV audio inputs try using a separate audio lead from the DVDR to the TV most will have an AV input normally with two mono inputs this will also identify which channel has the fault if any.
LOL
Jul 12, 2009 | Philips DVDR3380/05 DVD Recorder
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Having problems connecting dvd player to my tv
Normally a DVD's output would be:
Yellow - video
White - audio left (in some models mono)
Red - audio right
Based on your post/description, your movies will play normally. You simply left out the red (right output) hence you will not get stereo effect (which is immaterial since your TV is mono).
The correct procedure calls that you connect the red & white to a stereo amplifier.
Alternately, you can use the adapter shown below to connect the white & red and make them a single RCA male out.
Hope this be of use/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 17, 2007 | Televison & Video
Philips 42PFL5332D 42 in. LCD Television Logo
219 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
