Question about Refrigerators
Kitchenaid auger motor for the ice maker
The problem is that I cannot get the peice that sits in front of the frame off because it turns in side the part that needs replacing. Any ideas?
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
  • 212 Answers
SOURCE: I have a GE side-by-side stainless refrigerator,
your auger motor could be bad. first i would check the micro switch that the lever hits inside the dispenser housing.
Posted on Jun 24, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
Sea Breeze
  • 4625 Answers
SOURCE: Ge model gsl251frfbs side by side. Ice
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Posted on Dec 16, 2009
  • 256 Answers
SOURCE: Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Posted on Feb 22, 2010
0 characters
1 Points
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
I have a KitchenAid Superba refrigerator, side-by-side. It is about 14 years old. The model number is KSRD250GSS01. This part fell out of my ice maker yesterday. The auger doesn't turn and the motor d
That roller and pin is used to activate a micro switch which turns on the motor. You will either have to remove the ice maker to locate where it came off of or replace the whole ice maker. Chances are it's broken (can't see it very well in the video) and you have no choice but to replace the whole unit. Good luck!
Nov 22, 2012 | Refrigerators
Our ice maker makes ice, but the dispenser just grinds and clogs up with ice shavings.
Hello there,
When there is a problem with the motor that opens and closes the dispenser is when you will be experiencing such problem as having the ice maker making ice but not dispensing them
Most likely frozen up, known problems with this on kitchenaid. Try removing the auger motor and thawing it to see if it will then run.Your auger motor may be frozen, use a hair dryer on it and see if it starts turning again.
The best, if not easiest way to access the auger motor is pull it out. It's just four screws, two on each side of the fork assembly. The white plate and auger motor will come out together. There is a quick disconnect for the wires.there are boot kits to install over the motors to prevent this or just put it into a plastic zip lock bag with the shaft poking thru a hole in the front.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | KitchenAid KSCS25FKSS Side by Side...
Will not drop cubes fills with water but does not rotate to push out cubes
first is it the ice maker that doesnt drop the cubes or the auger motor on the door you have to determine if your icemaker is droping the cubes into the bin if its not the replace the ice maker if it is replace the auger motor on the door you can find both of these parts at marcone hope this helps
May 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Sub zero 690 ice maker
also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Jul 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
