Question about NEC LT 260K Multimedia Projector
Projector bulb drive circuit failure.
My NEC LT260K does not light up the lamp everytime it is switched on.
When it eventually does, it goes off within minutes, (the lamp drive panel heat-sink gets very hot) after that it takes for ever to get it to light up again. Sometimes the next day!
The green light comes up all the time as is normal.
The picture is ever so bright and clear when the lamp comes on..
What can I do? I am an electronics repair-man with a lot of experience, how can I get the schematics?
Anji, Nigeria
  • Anonymous Apr 07, 2008
    I am having the same problem. The porjector comes on with a good picture for a minute or two then goes off. The status light then goes red and goes into a six blink sequence. The power light goes amber and is constant. I replaced the bulb about two months ago which cleared the problem for a short time.
  • kpaul79 Oct 30, 2008
    I am having this same problem with about 10 of these projectors, I am in charge of about 65 rooms with these units. They are dropping like Flies as we say. It doesn't look like anyone knows anything about this.
SOURCE:
SOURCE: NEC VT47 lamp won't light
I have 3 of these and all failed within weeks of each other with the same problem. The status light blinks 6 times telling me the lamp failed to ignite.
I fixed all 3 by opening them and shuffling motherboards around. I didnt order any new parts, call tech support or anything fancy. Just swapped boards.
Maybe they will keep working, maybe they wont. It might be worth a shot if you've run out of warranty though. It's not going to get any busted-er.
Posted on Nov 28, 2007
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
Gigatech
  • 259 Answers
SOURCE: NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
dhiman
  • 115 Answers
SOURCE: lamp not lighting
Reset the lamp and try it.
Posted on Mar 29, 2008
Gigatech
  • 259 Answers
SOURCE: Blinking status light
6 cycle (0.5 sec On,
0.5 sec Off) is a lamp error!
0.5 sec Off)
Lamp fails to light. Wait a full
minute and then turn on again.
Even though the lamp is not old there may be a defect in the lamp. I know the lamps are expensive but this may be the problem. If you have a lamp that was removed due to age but still worked you could use the lamp to test it.here is a link to the user manual:
http://www.iusb.edu/~libg/ims/VT570_MAN.pdf
Hope this helps. :}
Posted on Apr 02, 2008
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT260's shutting down
I think I have solved this issue with my LT260K. I too had shut downs after 5 minutes of operation. It roughly followed a replacement of the bulb. I repaired stereos in the 70's and 80's, so I was not going to let the projector get the best of me without a tear down. I cleaned the fan blades, checked their operation. I checked the continuity of the thermostat on top of the bulb bracket, but found no apparent failures. I did find a possible loose connector in the middle of the projector as it seemed loose as I was disassembling the unit (see 1st picture). 7c58d4f.jpgThen I checked for cracked or burned areas on the PCB's. During this I scanned as much of the solder joints as I could. In the 'old' days, the power supply area could get hot and make cold solder joints. I found what appeared to be heat damaged solder joints on the auxiliary power board (Lamp power). This is the one that is back right of the projector opposite the power switch. It is a vertical board that solders into the horizontal bulb power board. I resoldered these and I am up and running. USE CAUTION, I would leave this to a trained professional to repair. This requires major disassembly.18d84c8.jpg
Oct 30, 2008 | NEC LT 260K Multimedia Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
NEC LT 260K Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
