Question about Kitchen Ranges
Burner problem One burner is not working. I switch the problem burner to another burner location and it worked. I flipped up the top and I replaced the wiring and the receptacle and it still did not work. Do you guys have any suggestions? Thanks for any assistance.
  • honeycantdo Dec 09, 2007
    Thanks - I thought it might be the switch; however, I can't find any manual to show me how to replace it and I can't figure out how to remove the control panel to access the switch.
  • 83 Answers
Its probally your switch the one you use to turn on bad burner
Posted on Dec 08, 2007
SOURCE:
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
My kenmore flat top stove front burner quit working. I replaced the 9" element and it still will not work. Any suggestions.
your burner switch is wattage rated ( as all burners are ) you want to check H1 and H2 for voltage 220vac and replace it with the correct switch Rf,Rr Lf Lr some shafts on controls are colour codded
refer to your model number and proper switch and element location
Cheers
Dec 11, 2013 | Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Oven will not bake correctly when set to bake only the top element comes on
The problem is likely one of two things: Either the lower burner is shot and should be replaced, or there is a defect in the switch. The burner is the more likely problem if the upper burner is still working. If the lower burner works on any of the other settings it could be the switch, which would need to be replaced.
May 03, 2011 | Microwave Ovens
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Range JBP69 samller burner of the dual burner doesn't work...
These burners are not that difficult to get to, but you will have to get access to that burner or element to do testing. Screws hold the top down located just under the top front edge. Open oven door to see screws. Remove screws to lift up top. It will pivot on the back edge. You will see the elements. If you do not feel safe doing this get professional help.
Aug 01, 2008 | GE JBP65 Electric Kitchen Range
Single Burner Doesn't Heat Properly
1. Turn off power. 2. Determine type of burner. If it's a plug-in, test faulty burner in another receptacle * If it works, replace the original receptacle * If it doesn't work, replace the burner. * Replace other faulty components If it's a flip-up burner: * Disassemble and replace the faulty burner and any other faulty parts. 3. Restore power. 4. Test. *If it still doesn't work, call a repairperson.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Kitchen Ranges Logo
503 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
