How do I turn on the ILO MP3/WMA digital Audio Player w/1GB
New batteries have been installed. Memory card is in. What button is used to turn on/off player?
  • Anonymous Jun 27, 2008
    MY MP3 AUDIO PLAYER HAVE THIS ORANGE BLONG COMING EVERTIME I TURN IT ON
Dude, that means you need to hook it up, take all the music off of it (and the memory card if u have 1) and put all the music back on. It says that in the Manualand on the box you buy it in!
Posted on Oct 18, 2008
My mp3 player has a:
flash error!
please back up the data
and format the player
Message
What do I do to correct this message?
Posted on Aug 19, 2008
Remove memory card then press play
Posted on May 08, 2008
  • tim_bectell
    tim_bectell Jul 11, 2013
    ok i did that now it wont trun on
System Recovery for the ilo mp3 player,
because it has being formated .
Posted on Mar 16, 2008
SOURCE:
I have an ILO 2gb mp3 player. I download audio books to it, some mp3 format, some wma format. It will play some but not some others. Mostly the wma format. Can I do anything so I can hear these?
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Jul 27, 2010 | iLO (2 GB) MP3 Player
2GB SD Card Problem.
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
Jan 29, 2008 | iLO MP3 Player
Ilo 1GB Mp3 Player Only had for a month and quit working properly
YOU HAVE TO SYNC THROUGH MEDIA PLAYER - IT DOES NOT RECONGIZE SONGS IF YOU JUST COPY THEM ONTO THE SD CARD.
FOR VISTA -This player only seems to be able to transfer MP3 format with Vista, using windows media player syne. Unless someone found otherwise.
FOR XP PRO When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer FOLDER HEIRECY. The MP3 player is not able to reconginize the folder structure it usually creates by default.
Jan 05, 2008 | iLO MP3 Player
Adding a 1gb memory disk
open the battery door and insert the sd card into the slot provided
Dec 29, 2007 | iLO (2 GB) MP3 Player
Got a new SD Card + Card Reader but when I download my music on it...
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
Dec 25, 2007 | iLO (2 GB) MP3 Player
Innovage mp3 wma 1gb format error
plug in your iLO and go to "start" at the bottom of your screen and go to My Computer then go to Removable Disk and right click. Then go to format
Dec 20, 2007 | iLO (2 GB) MP3 Player
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Nov 30, 2007 | iLO MP3 Player
Free space????
I have always just copied from my music directly to ILO. Never used media player...and it always worked fine.
Oct 07, 2007 | iLO MP3 Player
519 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
