Question about Kenwood KDC-MP435U CD Player
No Bass In Sound
Don't know if this is specific to the deck, but I wired in the deck to my 94 4runner and for some reason I don't have any bass. I double checked the wiring and I'm pretty dang sure its right. Anyway, I also checked the speakers in the back where the bass usually comes out, and they are both fine. Is this a setting on the deck, or what?
I had this problem in my nissan truck and the solution was adjusting the fader setting.The tweeters and the larger speakers were separated in such a way that adjusting the fader setting fixed the problem
Posted on Jan 25, 2008
  • 1,512 Answers
Check that you do no have the speakers wired with polarities crossed over. "out of phase" this will have the effect of cancelling out the bass. I try to rememebr stripe is negative
Posted on Dec 14, 2007
SOURCE:
Sony cd player plug working but no bass come out
Your sub leval out put has to be adjusted on deck, Or you don,t have it wired up right, Or the amp is not set up (Right) Get some body to help you that no what in the (Hell) there doing,
Oct 31, 2012 | Kicker Car Audio & Video
Why is there four plugs on the back of speakers?
With four plug you will have a jumper from on plug to the other. (e.g. Positive to positive and negative to negative.) This is for single connection (two wires.) If you use two connections (four wires) you take out the jumpers. the bottom pair is normally for the bass and the top for treble. This is to make the speakers clearer, and sound better. As for louder,? I don't know some people think it does some don't. With better clarity of sound, you do get the feeling of it being louder.
Apr 27, 2012 | Audio Players & Recorders
I have a grounding problem with my new Ibanez GSRM20 bass. I don't have an amp, and run the bass directly into a recorder (home studio) and headphones. There is a hum that disappears when I touch...
You need to ground the recorder. Use a WYE connector to get access to the barrel of the guitar cable and find a good ground on a three wire cord wall receptacle. You don't say what model recorder you have which would have been helpful to us. We are surrounded by electric and magnetic fields and typically you can pick up 10 volts AC (with no real current) just as an antenna from the building wiring. Many music devices that run on "wall wart" power adapters have this problem. Also keep guitar away from wall warts as they emit strong magnetic fields for those that use conventional transformers.
Aug 02, 2011 | Ibanez GSRM20 GSR Series Electric Bass
My Mirage S10 subwoofer light comes on showing the subwoofer is on but I cannot get any bass sound to come on. How can this be resolved?
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
Jul 07, 2011 | Mirage Prestige S10 Subwoofer Speaker
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
Power to rubicon 404 no sound 4 channels of 2-way high pass
Check RCA,s at the back of the head deck, make sure sub is set to low bass frequency, make sure gain is turned up on the amp and head deck has subwoofer enabled and bass on. If you are powering speakers make sure the balance on the head deck is set to 0. Make sure it's wired up properly.
Jul 22, 2009 | Soundstream XTA240.2 Car Audio Amplifier
Sound is coming out but no bass
Make sure that the rca cables that you have coming out of the deck to the amp arent switched to highpass(no bass) and check the amp and make sure that the crossover is set to lowpass(LP) see if that helps
May 30, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
NO BASS
try hooking up the remote wire from the car to the amp turnon lead form the deck, some cars have factory amps that need a turnon lead
Don
Jan 02, 2008 | Pioneer DEH-P3600 CD Player
Kenwood KDC-MP435U CD Player Logo
69 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
