hi,
check the supply, might be about 12v dc on the inverter,
before extracting the transistors, and after extracting. and note it.
Comments:
Aug 17, 2009
- if there is a supply ( at least 12v) try putting back the ist pair and note the voltages on it.
Aug 18, 2009
- how is your monitor doing? did it work?
Aug 18, 2009
- the first pair, might possibly be OK
try it
you need also to check if there is voltages appearing on the supply
(collector side of the transistor, when turning on, it should be at
least 12V) of the inverter circuit
Aug 18, 2009
- try only the first pair,
if it works you need to order 4 transistors , 2 are your spare in case
resolder also the toroidal transformer pins
even with just one pair it will work, if the whole inverter circuits have a supply.
say supply is 12 v it passes through the toroidal transformer then goes to the collector of the C5707
without supply it wont oscillate it wont work.
from the main power supply it goes to an FET, this transistor controls the supply of the inverter circuits
Aug 18, 2009
- you might need to check on this also, might be a fuse?
Aug 21, 2009
- check these also
Aug 27, 2009
- how is it doing?, did it work?
Oct 05, 2009
- hope your monitor is now OK,
try resoldering the torroids for better performance
Oct 23, 2009
- if ever you are still having problem on your inverter, post what voltage are you getting at the collector side of each C5707, when the unit is plugged (1), and the unit is turned on ( 2),
be fast enough cause you will miss the voltage it only takes seconds to red, before it drops to zero,
better yet solder a wire ,connect it to your positive of your DMM and measure it to be safe
the negative of the probe to the chassis of the unit.
these point will determine what might possibly be causing the inverter to fail.
