Problems with the USB hub on P5GD2, running Vista
Well...i'm having some troubles with the USB ports...The PC is saying that I have no USB 2.0 ports installed (and so all my USB devices are running at a low speed).
This happened after upgrading my Bios to vers. P5GD2D07...before that, all went fine! I went to the official site, there's no driver compatible with Vista...may I force an XP one, or is there any other solution?
  • 97 Answers
So you mean that you change your OS from XP to Vista? Yeah it really wont work normal because the driver that you installed is not for VISTA compatible drivers. ANd also you cannot force to install an XP driver to a Vista OS. Try to look to google that MBR of your and find some compatible driver for your VISTA.
^_^
Posted on Feb 07, 2008
When my computer searches for new hardware, it recognizes it and then installs it as "Unknown Device" The device still will not work, however, because when I check it in the device manager it...
This device should be recognized automaticaly by the OS. There are some issues with Windows 7, though.
Make sure you are trying to plug it in a 2. USB port, rather than 1.1. This might cause you trouble (even though this will not be a problem if you have a new computer)
Connect the hub to the external powercord. Sometimes it is not recognized because the hub cannot drain enough energy from the port.
if you are using a desktop pc, make sure it is plugged in the rear usb ports and not at the ones up front.
refer to the manual for further assistance: http://www.dynexproducts.com/cms/documents/DX-B4PORT-B7PORT_09-0962_QSG_V4_ENG_Final_lr.pdf
May 22, 2011 | Dynex 7-Port USB 2.0 Hub
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Ibm x22 doesnt recognise external DVD drive, keeps messaging saying could go faster on USB 2 port, but thats it
Did you check in the bios if your USB ports are configured as USB 2? That could fix it.
If not possible, try uninstalling the USB Root Hub devices in the device manager, that can fix some USB problems.
Dec 14, 2009 | IBM ThinkPad X22 2662 Notebook
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
Dell precision 360 usb ports troubles, won't recognize any usb component or accesory, any usb mouse neither a usb keyboard, but they seem to be ok in the control panel.
Are you running XP or Vista?
If XP, go to control panel then to system then to advanced than to device manager. look for any YELLOW question marks and fix those.Especially in the USB Hub .
Mastersage
Feb 19, 2009 | Dell PRECISION 360 P4 HyperThreading 3200...
Cx7330 connection problems
try a different USB port (if running vista) - or try not plugging into a USB hub if doing so.
Mar 19, 2008 | Kodak EasyShare CX7330 Digital Camera
USB Peripheral Switch
do not use Front usb connection. try to use cpu backside USB port it wil work.
Feb 27, 2008 | Belkin BLKF5U201 USB Peripheral...
USB204N Micro
im using vista too, when i had 2 hubs only one was working. but i did have the hub plugged into the other hub once i linked it directly to the pc's usb port, it worked... the problem was i wanted that port for an external hard drive, but now i just plugged that into one of the hubs!! problem fixed
Oct 25, 2007 | Micro Innovations (USB204N) 4-Port
Computers & Internet Logo
617 people viewed this question
Alun Cox
David Payne
David Payne
