Question about Toshiba Satellite A75-S206 Notebook
Toshiba Satellite A75-S206 DVD\CD-RW drive problem
I have a Toshiba Satellite A75 laptop. I recently replaced the hard drive with an exact match purchased on e-bay. The new drive had all the original software pre-installed and the computer came right up with no problems except one, the combo dvd/cd writer won't read most cds. If I put in an audio, software, or dvd in the drive nothing happens. If I go to My computer and click on the drive I get a message: "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows." If I check in device manager it says that the device is working properly. If I put a copy of Windows(XP} in the drive it works fine(it comes up with the screen to install Windows) so I don't think that the drive is broken. When I check in my computer with a Microsoft cd in the drive(either XP or Office XP) it has no problem reading either of those disks. What can I do?
  • 66 Answers
Hello GeneMat,
I am Romeet,i will try and help you with this problem.Seems it could be an issue with the Combo DVD Drive's Driver Software or Firmware.
Try This:
From your Desktop:
Right Click " My Computer" Icon and select "Properties"
Go to "Hardware" Tab and select "Device Manager"
Under Device Manager, scroll down to the "DVD/CDROM Drives" menu and click on the plus ( + ) Sign next to it
Right Click the Drive name eg " Toshiba DVD-R TSST 2313" and select " Uninstall" Click yes to any prompts and restart your Laptop.
After rebooting, Windows XP should pick up the drivers again, so wait a while for it to complete and until it notifies you that " Windows successfully completed installing your new hardware" or something to that effect and then try using the software cds again
Best of luck!
Regds
Romeet
Posted on Dec 01, 2007
I need a cd driver for a75-s206
You can download the Drivers for Toshiba Satellite A75-S206
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 28, 2010 | Toshiba Satellite A75-S206 Notebook
I have a laptop Toshiba Satellite A75-S206 Intel Pentium 4 2.8GHz / 802.11b-g Wireless / 15.4-inch WXGA / 512MB DDR / 60GB HDD / DVD-ROM/CD-RW Combo / and I want to change the hard disk.I want a list with...
That takes an IDE HDD. They are universal so any notebook IDE HDD will replace that 1. I like Weatern Digital because they really are good about standing behind their hard drives. Now it only came with a 4200 RPM so when u upgrade purchase the 5400 RPM. If the bios firmware only supports the 60GB then u will need to format a larger drive with a second partition using admin tools as a mass storage device.
Aug 14, 2010 | Toshiba Satellite A75-S206 Notebook
Toshiba a75 s-206 problems helppppppppppppppp
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
Mar 06, 2009 | Toshiba Satellite A75-S206 Notebook
I AM TRYING TO INSTALL A NEW HARD DRIVE INTO MY TOSHIBA SATELLITE A75-S206 IS THERE A URL YOU KNOW OF WITH INSTRUCTIONS?
Various laptop mount hard drives differently.
Some are mounted on the bottom of the laptop behind a screwed panel and may be mounted in a cage and may have adapter that fit on the hard drive connector pins.
Other hard drives are fitted on the edges of the LH side or RH side of the laptop behing a plastic panel and this panel is held in place by a screw. Again the hard drive may be mounted in a cage and may have an adapter connector on the hard drive connector pins.
If you are not sure goto the Toshiba WEB site to download the user manual or service manual for your model laptop.
Jan 18, 2009 | Toshiba Satellite A75-S226 Notebook
My DVD drive on my Toshiba Satellite A75 S206 isn't recongized
I was able to find this by insomniac on CDROM Guide:
You don't need drivers for optical devices (CD and DVD drives) as Windows has native support for them.
It sounds like a corrupt Registry entry, which is common with XP.
The following should fix it.
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software.
Restart your computer
Dec 19, 2008 | Toshiba Satellite A75-S206 Notebook
Toshiba
Most likely needs the DC jack replaced as these are the same Singatron jack HP recently settled out on for class litigation. We've replaced thousands....
Sep 01, 2008 | Toshiba Satellite A75-S206 Notebook
I want to open my Toshiba Satellite A75-S206
Try this link. If you can't find the exact model don't worry, find one that is similar. You'll find that the more laptops you take apart the more they just aren't that much different.
http://repair4laptop.org/notebook.html
Jun 24, 2008 | Toshiba Satellite A75-S206 Notebook
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Toshiba Satellite A75-S206 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
