Question about Jenn-Air 30 in. CVG4280 Gas Cooktop
Exhaust fan comes on when burner turned on
Jenn-Air exhaust fan comes on every time the left two burners are turned on. It seems to work fine with right two burners. What's up with that?
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Posted on Apr 16, 2010
  • 51 Answers
The left side is set for your grill. This is normal.
Posted on Dec 07, 2007
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Ventilation system on Jenn Air CVG4280
My Jenn-Air had the same problem. When you install the drip pan for the burner module, there is a "finger" on the pan that is inserted into a hole in the front of the stove. If you look into that hole, you will see a lever switch. The finger on the drip pan on the burner module is supposed to push that lever switch down and turn the fan off, but over time the lever gets pushed down further and ultimately it does not get activated when the drip pan is installed.
You can either replace the lever switch, or you can try to pull it back into place and tighten the two small screws that hold it in place. Actually, I chose a third option and attached a small, flat spring to the finger on the drip pan.
Oct 17, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Cooktops Logo
490 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
