Question about Belling 24 in. IDW603 Built-in Dishwasher
BELLING IDW604 I have the above dihwasher and it is showing error code E4 what does this mean? Thanks Fran
  • 3 more comments
  • Anonymous Dec 03, 2007
    My idw604 is showing E4 too it says in the manual that it has overfilled I have got it to pump out but not to clear the message
  • Anonymous Jan 07, 2008
    I also have the same dishwasher IDW604 and need help to fix it, there is no water in the machine but it says in the book that code E4 means it has overfilled, can anyone help?
  • Anonymous Mar 07, 2008
    i have a idw604 and the E4 keeps bleeping and flashing, i have emptied the machine and it pumps out i just need to know how to get rid of the beeping and flashing E4 so i can use the machine again
  • Anonymous Apr 06, 2008
    Same problem with E4 - IDW604. Only used half a dozen times. Would be good if someone from Belling would come on here to help us out!!!!!
  • billie 39 Feb 15, 2009
    mine is 2 years old and just did it yesterday so do i have to pull it all out and tip it before i can use it? it's full of curry stuff!! nice job after a long night out.
    Problem Solver:
  • 7 Answers
I have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
Posted on Aug 01, 2009
  • Jayneydodger Jul 09, 2012
    Very helpful thanks. I tried the above but at first it didn't work, then I read further down the page that you should try disconnecting from the mains and tipping forward slightly. So we did this - the dishwasher is integrated so it means you have to undo the whole thing, disconnect the pipes and tip it slightly until all water comes out - but it is now working fine!! :-))
E4 now gone but now no lights to out on wash programmes.What next?
Posted on Sep 02, 2010
I have just renewed the salt box on my idw 604 then ran a full program to check for any leaks the machine completed this and then into the drying program I then swiched it off put the side panels back on put it back in place to find I have no power to the machine ( fuse checked) any thoughts.
Dave
Posted on Mar 28, 2010
Did what charlesrean (Solution 2)suggested and used a tea towel to take out the water from below salt cover but I also had to pull the dishwasher out slightly and tip forward a couple of inches. seems to have worked machine has started a new cycle no problem. Thanks guys
Posted on Dec 06, 2009
I had the same problem and had to call out the Service guy under the guarantee, he says the problem is caused by a small switch which is activated when the water does not drain away properly. He said my machine had not been fitted properly and was not level. I've called the kitchen company who fitted it to get it re-fitted. He said as soon as the machine was level the switch would re-set. I assume then if you could remove the machine yourself and turn it on it's side the switch would re-set, but I can't do that.
Posted on Jan 22, 2008
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Belling IDW604
I found the solution myself. On the bottom plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to tilt the machine and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.
Jan 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Belling 24 in. IDW603 Built-in Dishwasher Logo
2,657 people viewed this question
Top Belling Dishwashers Experts
Jeff Hogancamp
Jeff Hogancamp
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
