Back to:
Tags:
Gateway Keyboard
Mikomi wireless keyboard (by 10 users)
posted by jachar on Dec 01, 2007
i have bought a wireless mikomi keyboard and mouse. The mouse works but it says on setup the keyboard driver not compatable tho i have xp
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
9 Other Users Have The Same Problem
Comment by Guest, posted on Aug 04, 2008
my disc drive don't work and i need to install wireless descset mikomi.what can i do
Comment by Guest, posted on Jul 03, 2008
yep got driver as incompatable with my dell xp laptop
Comment by Guest, posted on Apr 10, 2008
the driver states that it is not compatable with either windows 98 or XP
Comment by Guest, posted on Apr 01, 2008
box says compatible with XP- disc says no!
Comment by Guest, posted on Mar 26, 2008
My computer tells me that the device is 'not' compatible with XP!!!! The box and instructions all say it is but the drivers are for Windows 98 only.
Best Solution
posted on Jan 21, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
does it have a control button for its volume??
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on mikomi wireless keyboard:
I don't want to Accept this solution
Solution #2
posted on Jan 06, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
Don't run the setup program. Instead reboot your computer and use the windows add hardware wizard to install the drivers from the CD. The windows hardware wizard will detect several different devices, allow it to install them all from the CD.
Thank You!
Solution #3
posted on Oct 02, 2008
Not Rated (0)
kuttimama
Rating: 0%, 0 votes
s i hav the same problem
Thank You!
Solution #4
posted on Aug 18, 2008
Not Rated (0)
redwales2
Rating: 0%, 0 votes
I have just bought this mouse and keyboard, and it came with a small cd for driver installation. However when I referred to the manual it says the cd is only for Windows ME. Is that your problem?
Mine are working fine without the disk. There are small buttons on the underside of the keyboard and also on the mouse. These need to be pressed before they will work.
Thank You!
Solution #5
posted on Jul 31, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Just plug in the hardware for XP! It works straight away. That's what I did! No disc or drivers needed!
Thank You!
Can you Help with these Keyboards and Mice problems?
Gateway (2520915) Keyboard
I received a used gateway computer it works perfect except...
Whenever i press the question mark sign i get this : ?...
I have got the same problem on my presario v4000. when...
When I am typing on my laptop my thumb hits the insert...
well when i plug the key board in it go's wakey and i...
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 10, 2008
I have the same problem say I dont have windows xp but I do????
Comment by Guest, posted on Jan 04, 2008
same problem telling me ive no xp did u find a solution for the mikomi deskset
Comment by Guest, posted on Jan 01, 2008
no driver for keyboard
Comment by douglando, posted on Dec 31, 2007
i have the same problem keyboard not compatible with my xp
Loading problems.
Repair Service
Find Keyboard and Mice Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
