Question about Hoover PE235 Front Load Washer
Hoover pe235 is there anyone who could post a picture of the control dial as all the print has dissolved off mine from stain remover.
Contact Hoover, they should be able to supply you with a new dial for not a lot of money. Warranty won't apply as it wasn't their fault. Good luck.
Posted on Dec 04, 2007
SOURCE:
I get what look like rust streaks on my white clothing when I wash them in my washer. The stains do not come out even with straight bleach. RIT rust stain remover will get them out, but there's not...
1. Iron or manganese in the water supply. • Avoid using chlorine bleach on rust stains. It will make them darker and more obvious. • When iron is dissolved in the water, use granular detergent plus a non-precipitating water conditioner, such as Calgon or Spring Rain*. Better results may be obtained by dissolving detergent and water conditioner in the wash before adding the clothes. Be certain that all clothes are down into the water before starting washer. • If the iron is suspended in the water (it will settle out), attach a rust filter to the faucet and inlet hoses or to the water line. • If iron or manganese stains are a recurring problem, the customer may need a special filter or chemical feeder installed in the home to remove these minerals from the water supply. To remove: Launder with RoVer* Rust Remover Part No. 057961 using the directions below: • Top loading washers: a. Fill the washer with water (no detergent), selecting a temperature suitable for the fabric (hot or warm). b. Add 1/3 cup RoVer and let it dissolve by agitation. c. Add clothes and allow washer to complete the cycle. d. Follow up with an additional wash with detergent.
Be sure to check the spin basket for rust spots also.
Jan 16, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
PE235 would not spin or empty. Now it wont cycle either
Check the filter at the bottom of the machine ,right hand side behind the plastic cover along the bottom. You may find a blockage in there.
Adrian
Aug 06, 2009 | Hoover PE235 Front Load Washer
Water filling the drawer but not going into the drum, maybe blocked with soap powder tried unblocking with a rod no joy....
Yes there is a blockage in the drawer.Try removing the lid after unplugging the power,and you may be able to reach down the front and squeeze the dispenser hose a few times may break up the soap.
Adrian
Jul 06, 2009 | Hoover PE235 Front Load Washer
Loud noise on fast spin
The drum must be removed to get at it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
[email protected]
Sounds like you have a blockage in the filter or the motor brushes have worn down.
Adrian
May 24, 2009 | Hoover PE235 Front Load Washer
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Dec 18, 2007 | Hoover PE235 Front Load Washer
Hoover PE235
stock is the dangerous condition for mechanic parts, knock the water in take with a plier not to strong but strongly do this when the humming sound, check for cloged hoses too..good luck
Aug 10, 2006 | Hoover PE235 Front Load Washer
Hoover PE235 Front Load Washer Logo
117 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
