Question about Panasonic Lumix DMC-FZ7 Digital Camera
RED DOT WHEN VIEWING OR PRINTING A PICTURE, THERE IS A RED DOT ON ALL IMAGES TAKEN WITH THE DIGITAL ZOOM ACTIVATED.  THE DOT IS IN THE SAME LOCATION ON ALL PICTURES. COULD THIS BE A BAD SENSOR?
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Posted on Jul 12, 2008
SOURCE:
In Chile just bought a camera Lumix DMC FZ70, zooming only works in automatic mode AI in the other modes only works zoom 1 to 3x, please indicate what should I do
First thing Ariel is to read the manual. Specs say it has something called 'Intelligent Zoom', so it might be by design.
Panasonic Lumix DMC-FZ70 / DMC-FZ72 Key Features:
  • 16.1-Megapixel 1/2.3" High Sensitivity MOS sensor
  • LEICA DC VARIO DC 60x (20-1,200mm) Ultra Wide-angle Zoom Lens
  • 120x Intelligent Zoom
  • POWER O.I.S. (Optical Image Stabilizer) with Active Mode
  • LSI Venus Engine Image Processor
  • 3.0-inch 460k-dot Intelligent LCD Display
  • 0.2-inch 202K-dot EVF (Electronic Viewfinder)
  • 1,920 x 1,080 60i Full HD Video Recording with AVCHD (MPEG-4 / H.264) Format or 30p in MP4 with the Dolby Digital
  • Built-In Wind Shield Zoom Microphone
  • Up to 9 fps continuous shooting
  • ISO up to 6400
  • RAW file recording
  • P/A/S/M Full Manual Control
  • iA (Intelligent Auto) / iA Plus Mode
  • Creative Panorama
  • Creative Control
  • Creative Retouch
  • Creative Video Mode
  • HDR (High Dynamic Range) mode
  • 3D Photo mode
  • Optional DMW-LT55 Tele Conversion Lens extends the zoom ratio to 1.7x to pull the subject far off even closer with minimum deterioration of image quality.
  • Optional DMW-LC55 Close-up Lens
    http://panasonic.ca/viewing/ALL/DMC-FZ70P/OI/vqt5b59-eng/vqt5b59-eng.pdf
Jul 04, 2016 | Panasonic Lumix DMC-FZ70 Digital Camera
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
How do i zoom
1. Toggle the MODE button to camera picture and press the SET button
2. Compose your image while viewing the LCD monitor
3. Press the ZOOM thumbnail button with the magnifier picture to activate the digital zoom.can zoom images up to 5 times
4 Press the shutter button to capture the ZOOMED image
Hope this helps, there wasn't a date on your e-mail so not sure when your Holiday was.
Good Luck
Missy S
Sep 03, 2008 | Vivitar ViviCam 3780 Digital Camera
Pictures won't upload onto camera
there is solution for viewing the other size files in ur camera sir.
because camera is designed to read only that size of images.
Jun 13, 2008 | Canon PowerShot A540 Digital Camera
What is the rate of continuous advance?
The speed is selectable from 3 types at the continuous advance. Continuous advance: Single shot AF: max. 1.8 fps (live view and anti-shake are activated for each frame. TIFF image cannot be taken), continuous AF: max. 1.9 fps (live view, AF, AE, anti-shake are activated for each frame. TIFF image cannot be taken.) Hi-Speed continuous advance: max. 2.7 fps (Anti-shake is activated for each frame. AF, AE, WB, and live view are fixed at the first frame. TIFF image cannot be taken.) UHS continuous advance: 7 fps. (Image size is fixed at 640x480. AF, AE, and WB are fixed at the first frame. TIFF and RAW image cannot be taken. Digital zoom disabled.) Actual speed may vary depending on the subjects and shooting conditions. * Three frames can be taken continuously in normal and Hi continuous mode. *In UHS mode, the images can be taken as much as possible to the limitation of the storage capacity. For reference, STD: 180 frames, FINE: 160 frames, X. FINE: 100 frames (approx.).
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
A/C adapter
There is an A/C adapter which is recommended for use with the D-595 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
A/C adapter
There is an A/C adapter which is recommended for use with the D-545 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
A/C adapter
There is an A/C adapter which is recommended for use with the D-535 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Telephoto images
The D-435 has a 4x seamless digital zoom. Press the zoom button with the T on it and a zoom indicator will be displayed in the upper right corner of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy,” which is normal when using the digital zoom
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
222 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
