Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Camera locks up
My camera freezes completely with the yellow lines on right side of viewfinder flashing.  I change settings and nothing happens.  I waited and turned it back on in a few hours and it was fine.  This has happened three times.  I can't count on it to work.  What am I doing wrong?
  • 2 more comments
  • beeswax68 Feb 23, 2008
    I am having the same issue. This is not the same problem sony is fixing (links below), I called and they quoted me over $300 to fix it and that's just a baseline, goes up from there! I also took it to a local repair shop and they quoted me about the same. He did however, say he believes it to be an autofocusing problem. If anyone has any feedback on this that would be great!
  • MJGESQ Mar 24, 2008
    Exactly the same as Melissa - shutter will not release and anti-shake scale is flashing. The manual states a CCD setup error and refers to KM service facility. 3 identical problems suggests design problem?
  • tassietony Sep 11, 2008
    Same problem but only with a new Sigma Lens I have just bought, it a 10-20mm with Sony mount. I have Sony lenses that work fine
  • tassietony Sep 30, 2008
    I have now been advised by Sigma that it is to do with the misalignment of the diaphram mechanism, as the real problems sems to be that the apaerture wont change to suit the conditions after a couple of shots
The above links are not connected to the above problem(s). I contacted sony because I'm having the same issue and they said it is unrelated to the black screen locking up thing that the links take you to. I'm being told it's an auto focus problem. I'm out of warranty (of course) and sony can't/won't help without big bucks!
Posted on Feb 23, 2008
This is a known design defect in the cameras and Sony is repairing them, even if your warranty is expired.
see this for Konica Minolta's official statement:
http://ca.konicaminolta.com/information/...
http://www.dyxum.com/columns/other/First...
Posted on Dec 09, 2007
SOURCE:
My canon EOS 400 D will not take a photograph. I have selected 'full auto' and when i press the shutter button the speed and f number are displayed in the viewfinder together with the number 9 at the right...
The flashing green dot is telling you that your settings aren't right for the conditions. You have to bring in the settings within range. As long as the dot flashes, nothing is set right. Put camera on auto mode. Then take a photo. look at what the camera set the f stop, iso, etc. That will help you learn to set manual settings in the right direction. I have a 30 d and it will do same thing if setting in the manual settings are not right.
Feb 20, 2011 | Cannon Cameras
Hi I have a fuji finepix camera. On the display screen there is a yellow icon of a camera with an exclaimation mark and vibration marks. Please explain what this is and how I get rid of it. Thanks
basically it means the camera is finding it hard to focus as there is not enough light. Set the camera to automatic and turn on your flash. when you put the flash on the yellow camera icon should disappear and you will see the picture in the viewfinder is a lot sharper. I have the same camera and had the same problem. Turning on the flash solved it.
Sep 04, 2010 | Fuji Cameras
Olympus Camedia D-565 Problem
you left it too long for a free replacement
But it is worth contacting Olympus as it is know this one was a lemon.
Jan 15, 2008 | Olympus Camedia C-350 Digital Camera
Problem Supercam AG-Dp 800heg
Hello Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Regards,
Muthu.M
[email protected]
Jan 04, 2008 | Panasonic AG-DP800H Camcorder
Fuji s5000
Above the screen display on the back of the camera are two small buttons. The left one is blue and the right one is marked EVF/LCD.
Push the right side button to change from the viewfinder to the screen.
You can download the manual here: http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProduct.jsp?prodcat=616756
Dec 29, 2007 | Fuji FinePix S5000 Digital Camera
Lights!Camera! No Action!
do you have a memory card installed?
is this camera new?
not seeing in the viewfinder is not a good sign.
if its a slr, the mirror is locked up, either by function or failure.
need to know if its a slr or small format point and shoot to offer further advice.
Dec 21, 2007 | Canon PowerShot S3 IS Digital Camera
Digital Lines in my photos
I have contacted nikon servicing centre and they requested to see the camera, they didn't tell me what the fault was but they managed to fix it they charged me £ 190 but at least I have my camera back and is working fine...
Oct 11, 2007 | Nikon Coolpix 8700 Digital Camera
Mode switch
my dimage z5 and see alot of problems on ebay the net ....anyways being a tech for 25 years the cover came right off and u can see the switch is surface mounted. there is supposed to be a plastic lever coming out to manually engage to outer switch but missing ...upon closer inspection i could see alot busted up chards of small plastic ...the insideof the switch was completely ruined for bits where falling out...its just stuck in main veiwfinder. cant find the part itself anywhere on net. heard sony bought out minolta. my only bet is buy a broken camera with different prob. on ebay. Larry
Jan 26, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta Dimage S414
I have exactly the same problem, I'm guessing that the flash capacitor has died. I'm using the camera for outdoor work only at the moment, when I get desperate I might try taking the top off to see if I can find the capacitor.
Aug 24, 2006 | Konica Minolta DiMAGE S414 Digital Camera
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
216 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
