Dishwasher not draining. Also when switching on there is no water being drawn into washer. I have checked the filters etc and they seem ok. Is this a pump problem?
not drain...check pump clean and inspect for damage may need pump kit no water...check inlet valve...flood control switch...put flood control float on under bottom rack
dw 927 zannussi! changed motor seals, now fills with water runs for several seconds then cycle...
(More)
dw 927 zannussi! changed motor seals, now fills with water runs for several seconds then cycle sticks?
Asko dishwasher all lights are flashing. The cycle hasn´t finished, the water...
(More)
Asko dishwasher all lights are flashing. The cycle hasn´t finished, the water hasn´t drained and it shounds like the pump is not working properly.
