Brother HL_5280SW Clack and pages curling
Two months old.
Second toner cartridge(OEM).
A couple of hundred pages later.
1.) When printing there is a loud "clack".
This happens while the first page is printing, during multiple pages printing or while the last page is printing.
2.) The pages are now curling up as they come out. This causes them to push out of the tray and lose the order they are in as they pile up on the floor.
Thank you.
  • Jeffrey T. Schinkel Dec 02, 2007
    We tried new paper of better quality and have tried it once.
    No clack and no curling!
    Thanks.
  • 1,113 Answers
When paper is damp and runs threw the fuser in machine paper dries out and curls, try fresh paper, see this link about paper. Try a fresh sealed ream of quality paper
I dont have this model in Australia but it looks the same as the HL 5270 and there is bullitin released on these to eliminate paper curl, they upgraded the fuser and exit guide to fix this problem, yours is 2 months old so is covered by warranty, contact brother in your country to have it fixed.
Posted on Dec 02, 2007
SOURCE:
What might cause my Brother HL-2040 to leave black blotches and an overall gray appearance on print outs?
if your drum is new and still you are getting a problem of dark background then you have to replace the toner cartridge.
Jul 26, 2014 | Brother HL-2040 Laser Printer
I get blotches on my printouts on my Brother HL5270. I have tried "cleaning sheets" and also tried the toner and drum from another Brother printer which prints OK - still get the blotches, so...
First, the print head may be getting clogged and you need toremove the print head and soak (a couple of hours) it in warm distilled waterto dissolve the dried ink. Blot the print head dry with a lint free cloth beingcareful not to rub the electronics. Second, the new ink cartridges (if they arenot OEM) could be causing a problem. Reloaded or second party cartridges maynot always match the specifications for quality required by the printermanufacturer and may accelerate "gumming of the print head". Anotherpossibility of this problemis toner leak. Check if your toner leaks in the rubber filter and cause it to fall and the quality of your prints badly. Hope this willhelp you. Good Luck.
Aug 01, 2011 | Brother HL-5270DN Laser Printer
Brother hl-2030 - hi, is it possible to know how many pages a drum has printed?
Most laser printer do not have a page counter, because the toner cartridge may come in a couple of toner sizes and there is no way of accurately determine how much tone is used on each page as this can vary considerably.
If the printer gives a message that the toner is low, you can get several more prints by shaking the toner in a horizontal position and placing it back into the printer.
Dec 02, 2010 | Brother HL-2030 Laser Printer
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jun 24, 2010 | Brother HL 5250DN Laser Printer
Brother Printer 2150N - toner light has come on & toner is OK
Bought a 2150 in 2007. In 2008 toner light came on. Bought a new toner cartridge and installed. Light would not go off. Called Brother. They had us do the following:
1) Turn power off
2) Open front cover
3) Press white button (left side) 2 times and hold
4) Turn power on
5) Press white button 6 times and hold. All 3 lights should come on.
6) Close cover
7) Press blue button 3 times. Should print demo page.
We took the new cartridge out and saved it. The original is still working fine.
Feb 24, 2010 | Brother HL-2150N Laser Printer
I have the Brother HL-4070CDW and I have a TONER LIFE END message and it will not allow me to print anymore. How can I make my printer keep printing until I see visible quality issues?
With the front access door open, press and hold the cancel button. While still holding the down the cancel button, press and hold the reprint button... you should now see the toner reset menu. Why we can't get there from the machine info/reset menu to begin with, well, guess Brother wants to sell you more toner. ;^)
Dec 07, 2009 | Brother HL-4070CDW Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother HL 2140: Toner ledlight lit, stopped printing. Cleaned Coronary Wire. Toner Cartridge new - 2 weeks old.
Hi Adsl34xg,
The cartridge that comes with the printer (or starter cartridge) has a yield of 1,000 pages @ 5% coverage. It probably really has run out of toner. Replace with a new cartridge to see if you can print. A replacement cartridge should give you 2,500 pages @ 5% coverage.
Dec 17, 2008 | Brother Office Equipment & Supplies
Makes click a clack noise and toner cartridge wont come out!
Toss it.
These are 'disposable' printers. You can get a new one for less money than it would cost to fix.
Feb 20, 2008 | Brother HL-2040 Laser Printer
97 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
