Question about HP iPAQ RZ1710 Pocket PC
Doesn't turn on-tried everything-hard-soft reset
im charging the ipaq but the orange charging light doesnt even turn on.
tried hard and soft reset!
helllp plz
  • 2 more comments
  • Susieboo89 Dec 03, 2007
    yes im having same problem, got a new battery and was told a T5 screwdriver would fit but it didnt, anyone know the correct size?
  • laeschbach Jun 30, 2008
    same problem, will not recharge, no lights come on showing its charging, changed battery and still no charge.
  • sasoriipaq Oct 01, 2008
    it just happened to me when i tried to use an emulator now it wont even charge please if anyone knows the answer HELP
  • Desi man Oct 28, 2008
  • 25 Answers
Did you try replacing the battery?
Posted on Dec 03, 2007
Try T6 Torx
Posted on Mar 27, 2008
Have u presses the button on the bottomon the left the reset one like a really small hole?
Posted on May 08, 2008
Im download app into my hp ipaq,then it hang/ not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
Ipaq h5455 wont stop wibrating and i cant reset it
try a hard reset - it will restore to the original state. it removes all files and programs in the memory files in a storage card wont be affected.
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Mar 21, 2008 | HP iPAQ H5455 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
Will not come on at all
After a hard reset you must do a soft reset to enable the battery.
Nov 29, 2007 | HP iPAQ H5550 Pocket PC
HP Ipaq rz1710
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Sep 16, 2007 | HP iPAQ RZ1710 Pocket PC
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Ipaq rx3115 doesnt turn on!
I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RZ1710 Pocket PC Logo
297 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
