RCA 35V432T 35" TV
Problem for RCA 35V432T 35" TV
RCA 27v520t will not turn on
By lawnlady52 on Aug 17, 2009
During a storm the TV came on, and I turned it off, a few minutes later it came on again, and I turned it off. Went to turn it on later and it would not turn on. The power button shows the red light but if you press it nothing happens, no clicking, no indication that I pushed the button.
Solution #1
posted on Aug 17, 2009
Not Rated)
nettiser
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 1460 votes
That's because somehow the lightening caused a fault in the power board.
Ypu can try an unplug for 2 hrs and then reconnect and start again If that dosn't work you will require intevention to replace the power supply
Was this helpful?
Yes
No
Popular Solutions for RCA 35V432T 35" TV
Questions and Unsolved Problems for RCA 35V432T 35" TV
Do you recommend RCA 35V432T 35" TV?
Answer
Answer
Power comes on once or twice then wont come back on for days.
Answer
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i... (More)
Answer
No sound when connected to cable. No sound when disconnected from cable and the audio output cable... (More)
Answer
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA 35V432T 35" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
