Question about AT&T 1717 Digital Answering Machine
I have an older modek AT&T answering machine ...and I dont have a manuel and I have it running ok an all but when i set my clock , it just stays at that time... it dosnt atualy work, every time it takes a message it gives the same time that it was set to last. I dont have a manuel for this answering machine system but it works fine all except that....Its an AT&T answering machine and it has AS60 on its top right corner, beneath it is the letters >ABS< also it has a bar code tag beneath it as well.
    New Friend:
I want to model letter in efx
Posted on May 01, 2013
  • 61 Answers
SOURCE:
I dont have the manuel for my proline clock ipod docking system
proline docking station model number crd1001 radio just working no sound nothing else comes on why
Aug 30, 2012 | Audio Players & Recorders
I want to connect my fax from my cannon mx340 and dont have a instuction manuel can some help me?
Plug in the RJ-11 cable at the phone jack and the MX340. Press the Fax button and then the Menu button to get the Fax Settings menu. Press the left/right arrows to highlight Fax Receive Mode. Then press OK. Select Telephone Priority Mode (you will always pick up the handset and then put it down if the call is a fax. If an answering machine is connected the Fax will be automatically answered), Fax Priority Mode (the fax will be automatically received. If you hear the machine's ringtone, pick up the handset and press Stop to answer the call.), Fax only or DRPD (distinctive ring - available extra from your telephone company). Press OK to save the setting. If you choose DRPD, you will need to teach the distinctive ring by calling the MX340 after setting the machine to listen to the ring. (See the manual.) To fax out, press Fax, put your item to fax face up in the ADF and then dial the fax number of your receipient.
Canon has the manuals for the Pixma MX340 available here: http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340?selectedName=BrochuresAndManuals#BrochuresAndManuals .
I hope this helps.
Jun 12, 2011 | Canon Office Equipment & Supplies
Need to change the clock in my jimmy and dont know how,,theres no manuel
I found this solution already was answered by: chavezemail
Rank: Wiz gmc.gif Expert
Rating: 87%, 24 votes
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
correct hour appears on the display.
Jul 12, 2010 | 2000 GMC Jimmy
Setting up the answering machine
someone gave me this phone and i cant figure out how to leave a message for the answering machine... help, i dont have a manuel.
Mar 17, 2010 | Uniden Cordless Phone
Looking for manual for UX-107 info/directions for use older machine but still works
OK simplego to http://www.sharp.com , search for UX-107 user's manuel and download user's manuel from Sharp and your are done.
Mar 07, 2009 | Office Equipment & Supplies
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
Maruzen time recorder
i think you need to explain better i.e the type and the model of the stuff you installed.
Feb 04, 2008 | Computers & Internet
Weekend alarm cancel function
hit the cancel button then the wake1 or wake2 button as you need to cancel them.
Oct 28, 2007 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Clock resetting problems
You might contact your cable provider and see if their system indeed is broadcasting this subcarrier information. If so, is their system on the correct time? You might be able to turn this feature off on your VCR. Another thing to try, is disconnect the VCR from the cable system, set the clock, and see if it stays on time. This may indicate whether it is indeed locking it's time to the cable provided time.
Apr 12, 2007 | Sharp VC-H800U VHS VCR
AT&T 1717 Digital Answering Machine Logo
301 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
