Question about Sony Handycam DCR-TRV480 Digital Camcorder
Camera will not accept mini-dv tape anymore
I have two Sony DCR-HC42 digital camcorders with the same problem. Whenever I insert a tape it slowly goes in. After a while it flashes the error message: "Re-insert Tape."
If I eject the tape it comes out very slowly (or not at all).
It used to be okay if I just reinserted the tape, but now it won't accept any tape.
I tried a head cleaner, which surprisingly seem to fix the problem. But now noting helps.
Any ideas?
- David
I have the same problem with the tape in a DCR-TY480. Was intermittent at first, now permanent. Re-setting the camcorder as suggested elsewhere did not help. Less than two years old - 6 months of this problem. Very little use.
lsk
  • jeremyeagle Nov 15, 2008
    tape does not eject!
    Problem Solver:
  • 12 Answers
The fact the head cleaner seemed to work suggests to me dust may be an issue. Despite not being very old, try using an air canister to clean the inside. I had a similar problem with a vdr and it ended up requiring proper maintenance- the mechanism went faulty itself. Unless you are happy to open yourself and give a general clean, I would consider this. Costly however. Sorry cant be of more use.
Posted on Jul 28, 2009
    Champion:
  • 287 Answers
Is sounds like something got on the drum/video head ,that is sticky causing the drum not to spin when you put a tape in. You say that putting a tape cleaner in helped, and sometimes they will help ,but tape cleaner are not as good as having it cleaned by someone like me , a qualified Technician.
www.megaone.com/larry. or take it to someone closer. Larry
Posted on Jul 16, 2009
SOURCE:
Do i need a sd card o make camera work
You can't make the DCR-HC42 work with an SD card. This camcorder uses DV tapes, or Memory Stick Duo or Memory Stick Pro Duo memory cards.
Jun 06, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony camcorder
pls clean the head of camera using DV tape cleaner cassette and see if it helps pls do rate me if it helps to fix ur problem
Feb 25, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-TRV480 Digital Camcorder Logo
81 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
