I just bought this TV and try to hook up a Playstation 3 on it and I can't get it to work. I use a HMDI cable but only get the same message. "Not supportive mode"
I can't find any data in the "Display Modes" on the TV. Not with numbers. Only, Dynamic, Standard and one more I can't remember at this time.
Please help.
Using another cable it works, with a BAD resolution and in bleck and white.
What can I do in order to get this to work?
Thank you
Lotta Asp Andersson
Santa Ynez, CA.
Comments:
Dec 04, 2007
- Thank you.
The problem is solved. I don't know how as I tried to lower the output without success, but with both HMI cable and regular connected at the same time it all suddenly started to work.... with the PS3 in 1080 resolution....
Weird, but I'm happy :):)
this is a 720p set and while it will process a 1080i signal your ps3 is probably set for 1080p..you need to lower the output resolution on the ps3 to get it to work on this set
tv refuses to come on, have power going to tv, is there a reset i can do. or what do i do to fix...
(More)
tv refuses to come on, have power going to tv, is there a reset i can do. or what do i do to fix problem
