Home | Fujitsu | 18C1 Air Conditioner | Have Fujitsu inv...
Fujitsu 18C1 Air Conditioner
Problem for Fujitsu 18C1 Air Conditioner
Have Fujitsu inverter floor type,12 mths old.
By bobkaryl on Aug 17, 2009
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues when turned off by remote but no heat. Manual says "immediately stop operation and consult authorised service personnel". Did this, they unsure and say turn off at isolating switch for one and a half hours then try again. Third try this has worked but did it again and again two tries before starting, going okay presently.
Any ideas what this code is advising?
Popular Solutions for Fujitsu 18C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18C1 Air Conditioner
Do you recommend Fujitsu 18C1 Air Conditioner?
Answer
Answer
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries... (More)
Answer
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split... (More)
Answer
I have power to the indoor unit,but the operation light does not come on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
