Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side regrigerator
My freezer started having frost on the back of it, then quit freezing, you can turn it off and then back on a few hours later then it will work for a while. I have ruined so much food is crazy. Someone said maybe some kind of thermostat?
  • 4 more comments
  • Brenda_sue Dec 01, 2007
    Its almost 4 yo model GSS20IEPCWWW,
    Thanks, I did contact one, went into their shop, they finished the model number for me, and shook their heads, I say their cuz there was two of them doing the same thing. The told me it would cost around $300.00, said they would have to come out and test to find the problem, I really thought they were pulling one over on me, if they seemed to know the problem, why couldnt they just tell me so I can fix it myself. So, thanks, guess I will be calling them.
    Is that possible for me to fix, although just looking and the sealed system seems to have a 5 year warranty, that is in the sealed system part isnt it?
  • Brenda_sue Dec 02, 2007
    Thank you guys so much, I am going to attempt this myself... very helpful and next time will come here if I need an answer.
    One more question, I am trying to order the part and ge site will not acknowledge the part as a defrost heater, Is there some other way to word it? I am sorry, just trying to be self suffucient here lol with your help.
  • Rob Allenback Mar 26, 2009
    how do you get to the defrost heater on a ge monogram side by side built in model# ZISW42DYB
  • 248 Answers
You'll find that the defrost heater is the problem most of the time.
Posted on Dec 01, 2007
  • Gerald Griffin
    Gerald Griffin Dec 02, 2007
    The sealed system consists of the compressor, evaporator, the condenser and connecting tubing.
    The defrost heater is not part of this.
    To access this, remove lower back wall of freezer by removing screws on either side of light socket. UNPLUG REFRIGERATOR.
    Remove back wall. The defrost heater is at bottom of evaporator coils. It has a wire going to it on each side. Remove 2 screws, one on each end of it. Test unit for continuity. If you take to your parts store, they can test for you. Take your model number with you. If the glass tube is blackened, it's probably bad.
  • Gerald Griffin
    Part number should bbe, WR51X10053.
    This is a ge part number.
    It's a very common heater.
    You can always google the part number.
Fridge working intermittenly... if we unplugg it for a while and plug back in it starts to work fine. It seems as if when it gets to the defrost cycle.. it never starts back up.
HELP.
Posted on Jul 17, 2009
  • 447 Answers
Yes your refrig is not defrosting proper. Is this a pretty new ge?? Can you post the model#
  • joey  shearer
    joey shearer Dec 01, 2007
    Ok so yours doesnt have a thermostat. It has a main computer (motherboard), thermistors (sensors that measure temperature,like a thermostat but not the same), and a defrost heater. So diagnosis of your defrost problem is tricky. You may need to call for service. Make sure they are familiar with GE electronic control refrigs. Like i said in the beginning they dont work like older units and are more tricky to diagnose.
  • joey  shearer
    joey shearer Dec 02, 2007
    To answer your question, no that part is not in the sealed system. That is only a few parts that are still under warranty. If it happens to be the defrost heater that part is easy to change, however it is not simple to check all the components.
SOURCE:
GE GSCS3KGYSS REGRIGERATOR DEFROSTING
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 26, 2011 | GE GSCS3KGYSS (227 cu ft) Side by Side...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I havs a side by side and the top won't stay cold or freeze.
Cold air being heavier than warmer air will settle to the lower levels. Check for fan motor operation inside the freezer section. If the fan is not operating you meed service. Also check for frost on the back wall of the freezer section. If the fan motor does not circulate the air frost will form on the back wall, also if the defrost system is not functioning.
Dec 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore regrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
Aug 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
264 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
