Question about Frigidaire GLTF2940ES Front Load Washer
LOC code flashing on washing machine
Machine will not start. beeps 3 times and flashes LOC on led screen. I have unplugged machine, reset, made sure door was closed, etc. HELP have LOTS of laundry
  • jimmyb63 Dec 28, 2007
    I have the same problem. Flashes ERR and LOC and will not start. I do not see a selector button to turn to the "off" position though, so I can try their fix. I held the start and options button after turning it off for 5 minutes and nothing. Any help?
  • Anonymous Mar 22, 2014
    the door opens and closes but te machine won't start
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Posted on Dec 30, 2007
    President:
  • 1,294 Answers
Simple thing here. Unplug machine wait for 5 mins. Plug machine. Turn selector which was "off", to "on" position. Press "options" & "start" buttons together for over 5 seconds. And rate me pl.
Posted on Dec 02, 2007
Same error on our machine. This solution did not fix ours but I did figure out that we have a little lock (loc) symbol under our options and select buttons. Pushed and held them both at the same time, heard a pop which evidently unlocked the machine and we are back in business. We think our 1 year old was playing with the buttons.
Posted on Dec 09, 2007
SOURCE:
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Samsung vrt wf44aap/w front loading washing machine will not start cycle. Beeping and flashing 3E
Unplug for a few then plug back in. Sometimes his will reset the machine.
Jun 08, 2013 | Washing Machines
LED lights flashing
maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .
home led lights
May 22, 2012 | Zanussi ZWF1420W Front Load Washer
I have a power chair it is a jet 3 ,the lights flash , i know there is a code to reset it , so can you help me. i have had it repaired before and they just reset it but i need to now how,
Hi. Different numbers of LED's flashing mean different faults.
Your machine can be in "lock " mode.
To unlock it, turn the machine on.
Move the joystick full forward until it beeps.
Then move the joystick full reverse until it beeps.
The machine should then work normally.
If you still have flashing LED's, count the flashes between the pauses, and let me know.
Good luck. Neil.
Jul 05, 2010 | Jet 3 Ultra Power Chair
My cda washing machine keeps flashing up code FO4 and it is failing to start can you help?
Do not know your model number but give this a try .erase the flashing LED . hold the start button in for 2 seconds this should reset the machine . unplug from wall wait 5mins and try again .
Feb 22, 2010 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Kenmore 417.44092500 front load window shows Err then flashes LOC and the minutes for the particular load setting. Door doesn't lock. Tried to get into diag code setting on spin/drain and pushing pause &...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 08, 2009 | Washing Machines
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
672 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
