Dryers Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer is dead there is no buzz when you tun it on its dead, it worked one minute and just dead the next what could it be
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Aug 17, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183302
Points
12747
A blown fuse inside the cabinet. this needs a serviceman to remove the cover to access
I have a Kenmore Dryer from Sears Model 97292100. It was working fine for several loads the other day, but when I went out to get the next load out, it had not dried completely. I set it to run again, but...
Is the belt tight around drum. If yes, then there is a tripable thermistor in the heat tube. Small button on it that slight push on it resets device. If belt is loose but not broken, then it is off the tensioner b
May 05, 2017 • Dryers
When I push the button to start the dryer, it just makes a buzzing sound, but does not start. It was working fine 30 minutes ago.
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
4helpful
2answers
2004 Mazda 6 suddenly all radio and CD buttons dead
this just happened to me to. do you know whats wrong.? or how to fix
1helpful
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
1helpful
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Dryer wont turn on.
your motor is bad and to weak to turn over-sorry-mike
Dryer wont get hot in the am i try it it will wrk for one load then wont get hot same thing for 4 days now
I have a Whirlpool dryer with LP gas, 7 1/2 years old. It will fire up once or twice after started then the next time it is supposed to fire it will make a buzzing sound. No heat. It will not produce heat after this until it sits for awhile then the same thing, will fire once or twice then no more. I replaced the ignitor and this did not solve the problem although it did have a consistent firing for about 3 minutes immediately after I replaced the part. then it started buzzing again and would not fire anymore. The propane line doesn't appear to be the problem either since it will work initially. Also the gas water heater in the house works fine.
3helpful
The start button only buzzes and won't engage in the typical spin cycle?
start button energise a relay that latches open and provdes the current path for the very heavy draw of heaters, and motor.
the relay is dead, or dying and instead of locking open is fluttering like a doorbell (buzz buzz).
Not a repairable item, it is replaceable and not very expensive, much less than a new dryer, last one purchased was $29.99
Relays are common to many dryers, the local parts guy will have one to match if you take the dead one.
typical relay looks something like this, not all are transparent
Sep 06, 2008 • Dryers
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 • Dryers
Top Dryers Experts
john h
