Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dysan DC01 No suction
I had to take the cleaner to bits so as to repair a faulty connection to the motor. Since putting it back together, I have no suction through pipe, and poor suction in the normal position.
Everything else seems OK.. I've replaced the filters.
Any pointers would be appreciated.
Thanks
Rob
  • Anonymous Dec 27, 2008
    no suction
Hi Chris, thanks for taking the trouble to respond, but yes, I should have said that the rubber flaps at the bttom arein place. There is good suction at the point where the container that collects the dust and rubbish fits against the handle part of the cleaner.
Rob
Posted on Dec 02, 2007
  • 372 Answers
Hi.
Check that the black rubber flaps at the bottom back close the holes in the chasis when you switch on.
Let me know how you get on.
http://dysonmanuals.inc.io/
Chris.
Posted on Dec 01, 2007
I need a part for the Dysan DC35 Animal....the plastic clip that holds the bin and the head of the vaccuum together
Check both filters are in place and secure check brush head and pipe is not blocked
If still no luck phone Dyson helpline they will talk you through amy other checks yoi can perform yourself
Jan 09, 2017 | Dyson DC35 Digitial Slim Animal Cordless...
My dc01 wand wont pick up
Hi Davina,
I'm sorry to hear you're having difficulty with your DC01. If your machine doesn't seem to be picking up as well as it should be via the hose, there may be a blockage somewhere in the machine. The filters may also need to be washed or replaced.
To check for any blockages, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc01/dc01-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual1/clean-the-shroud
In normal use, the filters should be washed at least once every 3 months, as shown in the video below. Use cold water without detergent, and allow the filters to dry completely somewhere warm for at least 12 hours before replacing them.
This should resolve the issue, but if you'd like any further assistance or advice, please give us a call on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week, and calls are free from UK landlines.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lost suction from cleaning dyson roller brush
This is actually a very common problem that we see for repair on Dyson Vacuums. Usually what happens is that the vacuum doesn't loose suction like most people think. You can test this by feeling the suction power on the hose. If you have suction coming from here, then most likely the machine isn't clogged.
What happens is that the bottom soleplate on the vacuum cleaner can easily be re-installed the incorrect way. If this happens the brushes on the vacuum cleaner can not even hit the carpet, which makes the vacuum feel like it's not picking up, but when the suction is tested from the hose it has plenty.
We see a lot of Dysons come in for repair with this problem. The bottom plate is not flush with the rest of the vacuum cleaner. Here's a picture of what an improperly installed bottom soleplate looks like:
When the bottom plate is put back on the vacuum, you should make sure that the bottom plate (the purple colored part in the picture) is flush with the agitator housing tray (red part in the picture). If not, the brushes will not hit the carpeting, and the vacuum won't really pick up anything.
This is how a correctly installed bottom soleplate should look like:
This should be the first thing you should check on your vacuum cleaner as it's the easiest and most common solution. If this doesn't fix your Dyson, please just use the Clarification Request form, and let me know which exact Dyson model you have, and whether the vacuum has suction power from the hose, whether the brushes turn when set to the carpet setting, and how old the vacuum is. I'd be happy to try and further diagnosis the problem with you.
I hope that this was helpful to you. If it helped you, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner.
Thank you very much,
Chris J.
GoVacuum
Mar 31, 2010 | Vacuums
Loss of suction
You may have a colg in the power nozzle of hose. Disconnect the hose and drop a quarter through it.
Bob
http://evacuumstore.com/
Mar 27, 2010 | Kenmore Progressive 35922 Bagged Upright...
The suction isn't working. It is there, but wehn
Check hose to see if it is clogged. ALSO MAKE SURE ALL THE COMPARTMENTS ARE PUT BACK CORRECTLY.If the water resevoir isn't sitting correctly , you will lose suction. Check that hoses are corect as well.
Dec 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson DC01 Blocked Hose
unclip the hose and push a garden hosepipe throughit. that will clear any blockedge in the dco1 hose.
Jan 07, 2009 | Vacuums
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
179 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
