Sharp CV-P09FX Air Conditioner
Problem for Sharp CV-P09FX Air Conditioner
Sharp CV-P10NC AC unit it has a puddle of water coming down.
By tenhayo on Aug 17, 2009
I noticed every time I use the CV-P10NC AC unit it has a puddle of water
underneath the unit. It's already soaked my carpet in my home office. The drainage nozzle is closed.
What can I do to fix this issue?
Comments:
Aug 17, 2009
- Hello hmlee390, I really appreciate your prompt response. When I open the drainage nozzle and turn the unit on the water is pumped out from the top nozzle. Could the pump still be bad or clogged? Is there something else I should be looking at? Thanks
Solution #1
posted on Aug 17, 2009
Not Rated)
hmlee390
Rank: Guru
Rating: 91%, 140 votes
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Was this helpful?
Yes
No
Popular Solutions for Sharp CV-P09FX Air Conditioner
Questions and Unsolved Problems for Sharp CV-P09FX Air Conditioner
Do you recommend Sharp CV-P09FX Air Conditioner?
Answer
Answer
puddles forming every day...cannot locate leak by tipping over...
Answer
drained unit still nothin, seem like compressor is not working how exspensive is this part unit... (More)
Answer
My Sharp CV 10 portable AC is not cooling. The fan works fine but even 'mega cooling' function does... (More)
Answer
air conditioner stops every few minutes not on a timer and doesnt turn back on by itself.
Answer
I live in NYC and have a small room ( about 200 ) with 1 computer server, 2APCs and few work... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp CV-P09FX Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
