Question about Epson STYLUS CX3900 All-In-One InkJet Printer
He did'nt know ink
I replace ink but the printer he he did'nt know ink
  • FioNZ Feb 03, 2008
    Replaced black cartridge with genuine Epson T0731 black ink cartridge spec'ed for CX3900. I think I may have pressed the On button when I shouldn't have, after replacement and while the machine was charging ink - the On light was still flashing (I was impatient!). Now it will not recognise the black cartridge and no matter what I try, tells me it is an incompatible cartridge.
    I have:
    - replaced cyan and magenta cartridges successfully since then, and tried reinstalling the black at the same time - no joy
    - reinstalled the black cartridge umpteen times - no joy
    - turned the machine off and on again - no joy
    About ready to pick it up and shake it... but suspect this will bring only fleeting sense of joy.
    Do I just have to bite the bullet and buy a whole new cartridge?
  • Epson Master
  • 705 Answers
If the machine has not recognised that the ink has been replaced then the ink cart is most likely faulty. This is especially true if using compatible or re-manufactured inks instead of genuine ones.
Change the ink again.
Posted on Dec 02, 2007
SOURCE:
How to Bypass the Printer Ink Chip in a Dell 515
I have a Dell v515 on Windows 7 64bit. I just figured out how to bypass the printer chip counter. Start --> Control Panel --> Devices and Printers. Right click on your printer, choose Printer Properties. Go to the Advanced tab and click the Print Processor button. Choose winprint for the print processor and NT EMF1.006 for the default data type (I found this choice has the best print results). This does not reset the chip, but just allows print jobs to be sent to the printer without having to go through the Dell software. I am not sure how this works with scanning or copying. My guess is that there may be times that you have to change back to the original Dell print processor and LEMF for the default data type. Hopefully this works for anyone reading this. Good luck!
Jun 29, 2012 | Dell AllinOne Multifunctional (v515w)...
How can I fix my printer
This error usually comes up when the ink system fails...
-- first hold down the OK & cancel button...
-- And if does nt work take out the ink cartridge take out the power of the printer ..
-- And then reconnect everything...
Oct 13, 2009 | Office Equipment & Supplies
Tried to install a refilled ink cartridge. Then
The printer working does not depend on its cartrage... Cartrage is just like ink in ur pen... If the nib of ur pen breaks then u cant blame on ink... Check whether the gare of ur printer moves if its nt then there is some problem in gare shifting ic or the rotator machine check it by giving it to some computer service shop
Aug 03, 2009 | Office Equipment & Supplies
Ink cartridge won't release
The replacement process isn't always very intuitive. Fortunately, HP.com publishes a web page with detailed instructions:
Replace the Print Cartridge
Good luck.
Oct 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
NT Driver Availability
The only drivers available are Windows 2000 and XP and Windows 98/ME.
May 23, 2008 | Fargo Persona C30 Thermal Card Printer
Photos
give your printer a DIAGNOSTIC TEST , is a cleaning test procedure of the ink cartridges, there you should know if you need to replace the ink cartridges.hope this helps AJ
May 08, 2008 | Canon PIXMA MP470 All-in-One Printer
My printer
sounds quite compelling
Mar 08, 2008 | Epson Stylus C60 InkJet Printer
Printer will not print
Firstky u need to make sure that the printer drivers are nt corrupted, i wuld suggest u reinstall them, make sure u do nt have any paper jam, check 4 small paper pieces inside, listen if the printer tries to pull the paper in.
Feb 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Printer not printing
If you are using Windows NT or XP then you can download and run a driver finder executable from
http://downloads.drivershq.com/DriverDetective/DriverStock/DriverDetective.exe
It is for your Lexmark Z515. Good luck.
Dec 09, 2006 | Lexmark JetPrinter Z515 InkJet Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
